Issues running MX updater
Leogets
#1 Post by Leogets »
I am running MX Linux 19. I am having a problem running the MX Updater. I get the message
Full upgrade
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
Full upgrade complete (or was cancelled).
Not sure what to do.
Eadwine Rose
Re: Issues running MX updater
#2 Post by Eadwine Rose »
Please share your Quick System Info from the menu, thanks.
MX-23.6_x64 July 31 2023 * 6.1.0-39amd64 ext4 Xfce 4.20.0 * 8-core AMD Ryzen 7 2700
Huckleberry Finn
#3 Post by Huckleberry Finn »
With a sudo :
sudo dpkg --configure -a
Leogets
#4 Post by Leogets »
Thanks Huckleberry Finn. That worked :)
Huckleberry Finn
#5 Post by Huckleberry Finn »
Glad to hear that, also welcome to the Forum. You can mark the thread with 1 click:
Eadwine Rose
#6 Post by Eadwine Rose »
You're welcome from me as well :)
WolliRh
#7 Post by WolliRh »
I have same problem too. Unfortunately, I don't understand the proposed solution. Can you please explain to me in a little more detail what needs to be done to solve the problem.
the error message with system info.
apt-get dist-upgrade
E: The dpkg process was interrupted; You need to run dpkg --configure -a manually to fix the problem.
Full update completed (or cancelled)
This terminal window can now be closed by pressing one
any key to close it...
E: The dpkg process was interrupted; You need to manually run dpkg --configure -a to fix the problem.
full update completed (or canceled)
Press any key to close...
Quick System Info
System:    Kernel: 5.10.0-19-amd64 [5.10.149-2] x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10.0-19-amd64
           root=UUID=<filter> ro quiet splash
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
           dm: LightDM 1.26.0 Distro: MX-21.2.1_x64 Wildflower August 28  2022
Machine:   Type: Laptop System: FUJITSU product: ESPRIMO Q920 v: N/A serial: <filter> Chassis:
           type: 16 v: C$Z255 serial: <filter>
           Mobo: FUJITSU model: D3233-A1 v: S26361-D3233-A1 serial: <filter>
           UEFI: FUJITSU // American Megatrends v: 4.6.5.4 R1.46.0.SR.1 for D3233-A1x
           date: 09/21/2018
CPU:       Info: Quad Core model: Intel Core i5-4590T bits: 64 type: MCP arch: Haswell family: 6
           model-id: 3C (60) stepping: 3 microcode: 28 cache: L2: 6 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15963
           Speed: 912 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 912 2: 912 3: 903 4: 948
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
           Type: mds mitigation: Clear CPU buffers; SMT disabled
           Type: mmio_stale_data status: Unknown: No mitigations
           Type: spec_store_bypass
           mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: disabled,
           RSB filling, PBRSB-eIBRS: Not affected
Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
           vendor: Fujitsu Solutions driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
           class-ID: 0300
           Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
           loaded: modesetting unloaded: fbdev,vesa display-ID: :0.0 screens: 1
           Screen-1: 0 s-res: 2048x1152 s-dpi: 96 s-size: 541x304mm (21.3x12.0")
           s-diag: 621mm (24.4")
           Monitor-1: HDMI-1 res: 2048x1152 hz: 60 dpi: 102 size: 510x287mm (20.1x11.3")
           diag: 585mm (23")
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 20.3.5
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
           vendor: Fujitsu Solutions driver: snd_hda_intel v: kernel bus-ID: 00:03.0
           chip-ID: 8086:0c0c class-ID: 0403
           Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Fujitsu Solutions
           driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
           Sound Server-1: ALSA v: k5.10.0-19-amd64 running: yes
Network:   Device-1: Intel Ethernet I217-LM vendor: Fujitsu Solutions driver: e1000e v: kernel
           port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Drives:    Local Storage: total: 295.78 GiB used: 18.9 GiB (6.4%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN256HCHP-00000 size: 238.47 GiB
           block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
           rev: 100Q scheme: GPT
           ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1
           size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
           rev: 1.00 scheme: GPT
           SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Partition: ID-1: / raw-size: 54.17 GiB size: 53.02 GiB (97.87%) used: 18.9 GiB (35.7%) fs: ext4
           dev: /dev/sdb2 maj-min: 8:18
           ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 274 KiB (0.1%) fs: vfat
           dev: /dev/sdb1 maj-min: 8:17
Swap:      Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 2.87 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/sdb3 maj-min: 8:19
Sensors:   System Temperatures: cpu: 66.0 C mobo: 29.8 C
Repos:     Packages: note: see --pkg apt: 2170 lib: 1148 flatpak: 0
           1: deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/repo/ bullseye main non-free
           1: deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           1: deb [arch=amd64] https://repo.vivaldi.com/stable/deb/ stable main
Info:      Processes: 220 Uptime: 51m wakeups: 1 Memory: 15.52 GiB used: 1.97 GiB (12.7%)
           Init: SysVinit v: 2.96 runlevel: 5 default: 5 tool: systemctl Compilers: gcc: N/A
           alt: 10 Client: shell wrapper v: 5.1.4-release inxi: 3.3.06
Top
davidy
#8 Post by davidy »
a cmd one keeps handy
Sys76 LemurPro-mx-23.4, EliteMinis HM90-mx-21.3, Deskmini UM350-phoenixLite win10, Qnap 12tb nas, Protectli FW4C-opnsense(=゜ω゜)
zero privacy = zero security . All MX'd Up
UAP = up above people
#9 Post by richb »
@WolliRh
When you run the QSI utility, click “Copy for Forum” at the bottom and then just paste it here in your thread. That formats it properly for the Forum using code tags. I have formatted it for you in this topic.
3710sudo
#10 Post by 3710sudo »
Hello, i've just installed MX LINUX 21.2.1, and i can't use MX UPDATER (since i've installed WINDSCRIBE from the repo i think).
The updater ask me to "dpkg --configure -a" = when i run the command all the system reboot automatically, i've can only take a screenshot of the last screen before reboot :
if someone can help me !
Return to “MX Help”
