Please translate mx-faqs
Hello translators,
Something different to translate - whole sentences! The mx-faqs have been placed on Transifex. There are 41 strings, most are complete sentences, so hopefully the context is clear.
Please preserve the numbered html formatting blocks. Probably easiest as before to simply copy the English text from above and put your translation between the blue format blocks.
(Cyril, I know you have already translated the faqs, so it should just be a cut-and-paste exercise for you. But the faqs have been updated a bit since then, so you will want to check the English text. Also, a couple are already filled in. That's a result of some testing I did earlier, so you will want to check those too.)
Please post any difficulties you encounter. Thank you!
Re: Please translate mx-faqs
Thanks, OG!
Personal: MX-25 Fluxbox, ThinkPad X1 Carbon gen 9 with i7
- Eadwine Rose
- Administrator
*looks cross-eyed*
Dutch done.. *head falls on keyboard*
MX-23.6_x64 July 31 2023 * 6.1.0-40amd64 ext4 Xfce 4.20.0 * 8-core AMD Ryzen 7 2700
Agree with cross-eyed. That was heavy translating,
Henry
Henry
Thanks to you both. It is a lot, but I believe it will be a big help to users.
- Eadwine Rose
- Administrator
I sure hope so.. they better start installing in Dutch or I'm coming after them!
kidding, of course hehe
DE done! Well, now I have finally read the FAQ.
ES done.
__kernal 5.10.0-26-amd64 x86_64; Xfce-4.18.0; 8 GB RAM
__Intel Core i5-3380M, Graphics, Audio, Video; & SSDs.
HP Ryzen 5 17-cp3xxx with MX23.4 AHS & Liquorix 6.10-12~mx23ahs amd64
Did I already do that?Old Giza wrote: Sat Jun 09, 2018 11:13 am (Cyril, I know you have already translated the faqs, so it should just be a cut-and-paste exercise for you. But the faqs have been updated a bit since then, so you will want to check the English text. Also, a couple are already filled in. That's a result of some testing I did earlier, so you will want to check those too.)
I made help files but not FAQs as far as I remember. So here I go.
Greek done (I know there are some native speakers of Greek that frequent the forums, have a look and see if my translations can be improved - I'm sure they can)
