Automatic mounting of hdd on system startup:  [Solved]
Re: Automatic mounting of hdd on system startup:
#21 Post by fehlix »
seaken64 wrote: Tue Aug 16, 2022 12:35 pm Please copy the text output from the terminal and paste into the forum post between "code" markers.
No need to re-iterate what was already stated.
Thanks
Kester
#22 Post by Kester »
Hi fehlix,
Here is the file text you requested:
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
#Entry for /dev/sdc1 :
UUID=9e69356d-94db-4b4f-b620-fa052a82fd20	/	ext4	noatime	1	1
#Entry for /dev/sda1 :
UUID=629DBC5D48080494	/media/HDD	ntfs-3g	defaults,uid=1000,gid=100,dmask=0002,fmask=0113,utf8,x-gvfs-show	0	0
#Entry for /dev/sdc2 :
UUID=5144ed61-9a42-48e6-bac5-9d2c2e36e328	swap	swap	defaults	0	0
This has been a telling and educational experience for me in more ways than one so many thanks for your patience and dogged determination to help me.
I believe you have resolved this for me but I have yet to test with Grsync. Certainly permissions is set to read/write.
I'll post back after setting up a Grsync backup but probably tomorrow as my ancient eyes need a rest.
Kester
#23 Post by Kester »
UPDATE
Hi fehlix,
Great news - it all worked - Many thanks.
baldyeti
#24 Post by baldyeti »
I believe ntfs has been synonymous with ntfs-3g in debian for quite a while (they use the better maintained fuse/ntfs3g driver no matter what type fstab or mount specifies)
#25 Post by fehlix »
baldyeti wrote: Tue Aug 16, 2022 1:53 pm I believe ntfs has been synonymous with ntfs-3g in debian for quite a while (they use the better maintained fuse/ntfs3g driver no matter what type fstab or mount specifies)
Not with disk-manager, b/c we kept the original read-only options, in case someone needs readonly.
seaken64
#26 Post by seaken64 »
fehlix wrote: Tue Aug 16, 2022 12:59 pm
Thanks
Yeah, I know. Already edited the post. I didn't realize I hadn't read into page two of the thread yet.
Seaken64
