MX Package Installer - Vscodium - The repository is not signed.  [Solved]
hkjz
#1 Post by hkjz »
Hit:1 http://deb.debian.org/debian bookworm-updates InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
Hit:4 http://nl.mxrepo.com/mx/repo bookworm InRelease
Ign:5 https://repo.vivaldi.com/stable/deb stable InRelease
Hit:6 https://updates.signal.org/desktop/apt xenial InRelease
Hit:7 https://repo.vivaldi.com/stable/deb stable Release
Hit:8 https://repo.teamsforlinux.de/debian stable InRelease
Hit:9 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:10 https://packages.element.io/debian default InRelease
Reading package lists...
gpg: no valid OpenPGP data found.
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
Hit:3 http://nl.mxrepo.com/mx/repo bookworm InRelease
Hit:4 http://deb.debian.org/debian bookworm InRelease
Hit:5 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:7 https://repo.teamsforlinux.de/debian stable InRelease
Ign:8 https://repo.vivaldi.com/stable/deb stable InRelease
Hit:9 https://packages.element.io/debian default InRelease
Hit:10 https://repo.vivaldi.com/stable/deb stable Release
Get:12 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease [3,411 B]
Err:12 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 54678CF75A278D9C
W: GPG error: https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 54678CF75A278D9C
E: The repository 'https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease' is not signed.
hi, here is an report of an error
Re: MX Package Installer - Vscodium - The repository is not signed.
#2 Post by dolphin_oracle »
please provide the following:
1. quick-system-info
#3 Post by timkb4cq »
We don't run the vscodium repositories which are causing the error.
But running MX Fix GPG keys from MX Tools will download their public GPG key for you if the vscodium repo maintainers have uploaded it to the normal public keyservers as is customary.
#4 Post by dolphin_oracle »
the error could also be generated when a valid key is present if the entry in vscodium.list is not formatted correctly.
a fresh install from popular apps worked here, but if I messed with the list file entry, then I got the error message the OP presents.
hkjz
#5 Post by hkjz »
timkb4cq wrote: Tue Jun 10, 2025 3:55 pm We don't run the vscodium repositories which are causing the error.
Checking brave-browser-apt-release.s3.brave.com_dists_stable_InRelease
gpg: key 0x0686B78420038257: public key "Brave Linux Release (Brave Linux Release) <brave-linux-release@brave.com>" imported
gpg: Total number processed: 1
gpg:               imported: 1
Checking deb.debian.org_debian_dists_bookworm_InRelease
    Good GPG signature found.
Checking deb.debian.org_debian_dists_bookworm-updates_InRelease
Checking nl.mxrepo.com_mx_repo_dists_bookworm_InRelease
Checking packages.element.io_debian_dists_default_InRelease
gpg: key 0xD7B0B66941D01538: public key "riot.im packages <packages@riot.im>" imported
gpg:               imported: 1
Checking packages.microsoft.com_repos_vscode_dists_stable_InRelease
Checking repo.teamsforlinux.de_debian_dists_stable_InRelease
*** Keys not found on keyserver: 0x2FD80E00E6A6E47D
Checking security.debian.org_debian-security_dists_bookworm-security_InRelease
Checking updates.signal.org_desktop_apt_dists_xenial_InRelease
Checking paulcarroty.gitlab.io_vscodium-deb-rpm-repo_debs_dists_vscodium_InRelease
Checking repo.vivaldi.com_stable_deb_dists_stable_Release
dolphin_oracle wrote: Tue Jun 10, 2025 4:15 pm the error could also be generated when a valid key is present if the entry in vscodium.list is not formatted correctly.
  Kernel: 6.1.0-37-amd64 [6.1.140-1] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/vmlinuz-6.1.0-37-amd64 root=UUID=<filter> ro quiet splash
  Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.38 info: xfce4-panel wm: xfwm v: 4.20.0 vt: 7
    dm: LightDM v: 1.32.0 Distro: MX-23.6_x64 Libretto April 13  2025 base: Debian GNU/Linux 12
    (bookworm)
  Type: Laptop System: LENOVO product: 20QDCTO1WW v: ThinkPad X1 Carbon 7th
    serial: <superuser required> Chassis: type: 10 serial: <superuser required>
  Mobo: LENOVO model: 20QDCTO1WW v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
    v: N2HET40W (1.23 ) date: 10/17/2019
  ID-1: BAT0 charge: 36.1 Wh (84.5%) condition: 42.7/51.0 Wh (83.7%) volts: 16.5 min: 15.4
    model: SMP 02DL005 type: Li-poly serial: <filter> status: not charging cycles: 449
  Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Comet/Whiskey Lake note: check
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0x100
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 400/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 799 6: 800 7: 800 8: 800
    bogomips: 31999
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: gather_data_sampling mitigation: Microcode
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: itlb_multihit status: KVM: Split huge pages
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed mitigation: Enhanced IBRS
  Type: spec_rstack_overflow status: Not affected
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; PBRSB-eIBRS: SW
    sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-2,HDMI-A-1,eDP-1 empty: DP-1
    bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Bison Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 5986:114e
    class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.7 compositor: xfwm v: 4.20.0 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 5280x3600 s-dpi: 96 s-size: 1398x953mm (55.04x37.52")
    s-diag: 1692mm (66.61")
  Monitor-1: DP-2 pos: top-left model: AOC U3277WB serial: <filter> built: 2018 res: 3840x2160
    hz: 30 dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 801mm (31.5") ratio: 16:9 modes:
    max: 3840x2160 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: top-right model: Idek Iiyama PL2792Q serial: <filter>
    built: 2019 res: 1440x2560 hz: 60 dpi: 109 gamma: 1.2 size: 336x597mm (13.23x23.5")
    diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 640x480
  Monitor-3: eDP-1 pos: primary,bottom-c model: AU Optronics 0x2336 built: 2017 res: 2560x1440
    hz: 60 dpi: 210 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
    modes: 2560x1440
  API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.1.0-37-amd64 status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel modules: wl
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:15be class-ID: 0200
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth:
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
    bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 2 state: down bt-service: N/A rfk-block: hardware: no
    software: no address: <filter>
  Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff link-mode: peripheral accept
  Local Storage: total: 953.87 GiB used: 675.38 GiB (70.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 710 size: 953.87 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: VC3S500T
    temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 37.98 GiB size: 37.09 GiB (97.65%) used: 16.97 GiB (45.7%) fs: ext4
    dev: /dev/dm-0 maj-min: 253:0 mapped: luks-<filter>
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%) used: 201.2 MiB (20.7%) fs: ext4
    dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 274 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-4: /home raw-size: 899.98 GiB size: 884.78 GiB (98.31%) used: 658.21 GiB (74.4%) fs: ext4
    dev: /dev/dm-1 maj-min: 253:1 mapped: luks-<filter>
  ID-1: swap-1 type: partition size: 14.6 GiB used: 5.2 MiB (0.0%) priority: -2 dev: /dev/dm-2
    maj-min: 253:2 mapped: luks-<filter>
  System Temperatures: cpu: 60.0 C pch: 58.0 C mobo: N/A
  Fan Speeds (RPM): fan-1: 0
  Packages: 2463 pm: dpkg pkgs: 2449 libs: 1252 tools: apt,apt-get,aptitude,nala,synaptic pm: rpm
    pkgs: 0 pm: flatpak pkgs: 14
  Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.list
    1: deb [arch=amd64 signed-by=/usr/share/keyrings/brave-browser-archive-keyring.gpg] https://brave-browser-apt-release.s3.brave.com/ stable main
  Active apt repos in: /etc/apt/sources.list.d/element-io.list
    1: deb [signed-by=/usr/share/keyrings/element-io-archive-keyring.gpg] https://packages.element.io/debian/ default main
    1: deb http://nl.mxrepo.com/mx/repo/ bookworm main non-free
  Active apt repos in: /etc/apt/sources.list.d/signal-xenial-added-by-mxpi.list
    1: deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main
    1: deb [arch=amd64] https://repo.vivaldi.com/stable/deb/ stable main
  Active apt repos in: /etc/apt/sources.list.d/vscode.list
    1: deb [arch=amd64] https://packages.microsoft.com/repos/vscode stable main
  Active apt repos in: /etc/apt/sources.list.d/vscodium.list
    1: deb [ signed-by=/usr/share/keyrings/vscodium-archive-keyring.gpg ] https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium main
  Active apt repos in: /etc/apt/sources.list.d/teams-for-linux-packages.sources
    1: deb [arch=amd64] https://repo.teamsforlinux.de/debian/ stable main
  Processes: 325 Uptime: 7h 1m wakeups: 11421 Memory: 15.3 GiB used: 13.98 GiB (91.4%)
  Init: SysVinit v: 3.06 runlevel: 5 default: graphical tool: systemctl Compilers: gcc: 12.2.0
  alt: 12 Client: shell wrapper v: 5.2.15-release inxi: 3.3.26
Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
Hit:3 http://deb.debian.org/debian bookworm InRelease
Hit:5 https://repo.teamsforlinux.de/debian stable InRelease
Hit:6 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:7 https://updates.signal.org/desktop/apt xenial InRelease
Hit:8 https://packages.microsoft.com/repos/vscode stable InRelease
Ign:9 https://repo.vivaldi.com/stable/deb stable InRelease
Hit:11 https://repo.vivaldi.com/stable/deb stable Release
gpg: cannot open '/dev/tty': No such device or address
Hit:6 https://repo.teamsforlinux.de/debian stable InRelease
Hit:9 https://packages.microsoft.com/repos/vscode stable InRelease
Hit:11 https://packages.element.io/debian default InRelease
#6 Post by dolphin_oracle »
try editing the vscodium.list file to the following:
deb [arch=amd64 signed-by=/usr/share/keyrings/vscodium-archive-keyring.gpg ] https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium main
hkjz
#7 Post by hkjz »
hi @dolphin_oracle
it didnt help, acutally my update / updagre is broken now
mx@mx:~$ sudo apt full-upgrade -y && sudo apt autoremove -y && sudo apt autoclean && sudo apt clean && sudo dpkg --configure -a && sudo apt --fix-broken install && sudo apt update && sudo apt list --upgradable;
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
  gstreamer1.0-plugins-bad libgstreamer-plugins-bad1.0-0 signal-desktop
3 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 112 MB of archives.
After this operation, 78.8 kB of additional disk space will be used.
Get:1 http://security.debian.org/debian-security bookworm-security/main amd64 gstreamer1.0-plugins-bad amd64 1.22.0-4+deb12u6 [2,993 kB]
Get:2 https://updates.signal.org/desktop/apt xenial/main amd64 signal-desktop amd64 7.57.0 [108 MB]
Get:3 http://security.debian.org/debian-security bookworm-security/main amd64 libgstreamer-plugins-bad1.0-0 amd64 1.22.0-4+deb12u6 [766 kB]
Fetched 112 MB in 8s (13.2 MB/s)
(Reading database ... 356446 files and directories currently installed.)
Preparing to unpack .../gstreamer1.0-plugins-bad_1.22.0-4+deb12u6_amd64.deb ...
Unpacking gstreamer1.0-plugins-bad:amd64 (1.22.0-4+deb12u6) over (1.22.0-4+deb12u5) ...
Preparing to unpack .../libgstreamer-plugins-bad1.0-0_1.22.0-4+deb12u6_amd64.deb ...
Unpacking libgstreamer-plugins-bad1.0-0:amd64 (1.22.0-4+deb12u6) over (1.22.0-4+deb12u5) ...
Preparing to unpack .../signal-desktop_7.57.0_amd64.deb ...
Unpacking signal-desktop (7.57.0) over (7.56.1) ...
Setting up libgstreamer-plugins-bad1.0-0:amd64 (1.22.0-4+deb12u6) ...
Setting up gstreamer1.0-plugins-bad:amd64 (1.22.0-4+deb12u6) ...
Setting up signal-desktop (7.57.0) ...
update-alternatives is /usr/bin/update-alternatives
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for gnome-menus (3.36.0-1.1) ...
Processing triggers for libc-bin (2.36-9+deb12u10) ...
Processing triggers for mailcap (3.70+nmu1) ...
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
dpkg: error: dpkg frontend lock was locked by another process with pid 13304
Note: removing the lock file is always wrong, can damage the locked area
and the entire system. See <https://wiki.debian.org/Teams/Dpkg/FAQ#db-lock>.
Hit:1 http://nl.mxrepo.com/mx/repo bookworm InRelease
Hit:8 https://repo.vivaldi.com/stable/deb stable Release
Hit:11 https://packages.microsoft.com/repos/vscode stable InRelease
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
mx@mx:~$ sudo apt update && sudo apt upgrade -y
Hit:5 https://updates.signal.org/desktop/apt xenial InRelease
Hit:6 https://packages.microsoft.com/repos/vscode stable InRelease
Hit:8 https://brave-browser-apt-release.s3.brave.com stable InRelease
Ign:10 https://repo.vivaldi.com/stable/deb stable InRelease
QSI
    (bookworm)
  ID-1: BAT0 charge: 30.2 Wh (70.7%) condition: 42.7/51.0 Wh (83.7%) volts: 15.8 min: 15.4
    model: SMP 02DL005 type: Li-poly serial: <filter> status: discharging cycles: 450
  Speed (MHz): avg: 800 min/max: 400/4600 scaling: driver: intel_pstate governor: powersave
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 31999
  Type: itlb_multihit status: KVM: VMX disabled
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 678x382mm (26.69x15.04") s-diag: 778mm (30.64")
  Monitor-1: eDP-1 model: AU Optronics 0x2336 built: 2017 res: 2560x1440 hz: 60 dpi: 210
    gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes: 2560x1440
Bluetooth:
  Local Storage: total: 953.87 GiB used: 675.35 GiB (70.8%)
    temp: 28.9 C scheme: GPT
  ID-1: / raw-size: 37.98 GiB size: 37.09 GiB (97.65%) used: 16.93 GiB (45.6%) fs: ext4
  ID-4: /home raw-size: 899.98 GiB size: 884.78 GiB (98.31%) used: 658.23 GiB (74.4%) fs: ext4
  ID-1: swap-1 type: partition size: 14.6 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-2
  System Temperatures: cpu: 36.0 C pch: 38.0 C mobo: N/A
    1: deb [arch=amd64,arm64 signed-by=/usr/share/keyrings/vscodium-archive-keyring.gpg ] https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium main
  Processes: 291 Uptime: 11m wakeups: 2644 Memory: 15.3 GiB used: 3.37 GiB (22.0%) Init: SysVinit
  v: 3.06 runlevel: 5 default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 12
hkjz
Re: MX Package Installer - Vscodium - The repository is not signed.  [Solved]
#8 Post by hkjz »
@dolphin_oracle @timkb4cq
sudo rm -f /usr/share/keyrings/vscodium-archive-keyring.gpg
sudo gpg --no-default-keyring --keyring /usr/share/keyrings/vscodium-archive-keyring.gpg --keyserver keyserver.ubuntu.com --recv-keys 54678CF75A278D9C
sudo apt-get update
this 3 lines allows me to do updates/upgrades again
maye it will be helpful for the system upgrade from the Admin side
hth
