LLM chatbot forum integration?  [Solved]
retroD0d0
#1 Post by retroD0d0 »
Hey Everyone. Has anyone broached the idea of integrating a chatbot into the forum using the entire forum thread archive as context? Perhaps other mx documentation also? I've no idea if the site has already been scraped by LLM trainers, does/would anyone know? It might help users to get quicker responses and reduce unnecessary threads. Thoughts?
j2mcgreg
Re: LLM chatbot forum integration?
#2 Post by j2mcgreg »
No!
BV206
#3 Post by BV206 »
From what little I know (reading detailed reports from others) you can't rely on AI answers to be accurate. Maybe you get quicker responses but it would increase the number of forum posts when people find out the hard way they need correct aswers.
Re: LLM chatbot forum integration?  [Solved]
#4 Post by richb »
As indicated earlier no. And will not happen on my watch.
#5 Post by Adrian »
It's good to use the tools where they make sense. If you are on the forum it makes sense to talk to people, if you want to talk with an AI there are other sites for that.
#6 Post by Stevo »
What if we combine LLM AI with systemd?
MXPI = MX Package Installer
QSI = Quick System Info from menu
The MX Test repository is mostly backports; not the same as Debian testing
#7 Post by Adrian »
In MX style we'll let the user choose if they want to boot with InitV, systemd, or LLM.
Eadwine Rose
#8 Post by Eadwine Rose »
No.
MX-23.6_x64 July 31 2023 * 6.1.0-34amd64 ext4 Xfce 4.20.0 * 8-core AMD Ryzen 7 2700
Asus TUF B450-Plus Gaming UEFI * Asus GTX 1050 Ti Nvidia 535.216.01 * 2x16Gb DDR4 2666 Kingston HyperX Predator
retroD0d0
#9 Post by retroD0d0 »
Ok, guys, thanks for your responses, prevailing sentiment noted, accepted and possibly understood!
Adrian wrote: Tue Apr 08, 2025 8:37 pm It's good to use the tools where they make sense. If you are on the forum it makes sense to talk to people, if you want to talk with an AI there are other sites for that.
In a prompt with a Llama3b model, a question asking it to compare how MX Package Installer retrieves it's packages across both Popular Applications and manual package install returned a response indicating it had no idea. I think the first time I have encountered this answer. It simply had no context to give even a vague, non-descript answer. Maybe the question was dumb :confused: .(Heads-Up: follow-up thread on the same subject incoming :p ). It seems, forum.mxlinux.org wasn't scraped for this model instance's training and I am not aware of any agent which accepts tagging of an entire forum (as opposed to a webpage,pdf etc) as prompt context. This is the problem I was trying to solve for myself. Does anyone have any ideas?
Melber
#10 Post by Melber »
Why spend time formulating a query for AI when you could just ask the actual people who wrote MXPI here on the forum?
(I shall refrain from any further AI comment otherwise I'll get this thread locked too. ;))
Locked
Return to “Site Help”
