what is a good PDF reader on linux?
dotw
#1 Post by dotw »
I have tried many PDF applications on linux like master PDF editor, Okular, Evince etc. I was overall satisfied with the features that master PDF editor came with but when i need to copy texts from a PDF file, I can only copy from one page at a time. Another problem I face with master PDF Editor is that whenever I open a PDF file it always starts from page 1 even; it does not remember what page I was on the previous time. Luckily Okular does not have these two issues. However, annotating a PDF document with Okular is very annoying e.g., if i want to highlight a word I have to preselect highlight option and then highlight. Whereas i can just double click a word in Master PDF Editor and then choose highlight from the pop-up menu. Now, is there a PDF reader on linux that does not have any of these 3 issues? If not I see no options other than having to use windows as I am a student and I mostly work with PDF files
CharlesV
Re: what is a good PDF reader on linux?
#2 Post by CharlesV »
What windows PDF reader do you use?
*MXPI = MX Package Installer
*Linux -This is the way!
golf4fun
#3 Post by golf4fun »
Calibre has a viewer that might work. Also try foliate
dotw
#4 Post by dotw »
CharlesV wrote: Mon Feb 05, 2024 10:03 pm What windows PDF reader do you use?
Adobe acrobat reader and Foxit pdf reader. And they do not have any of these issues even on the free edition.
CharlesV
#5 Post by CharlesV »
Both are available for linux, however as I recall the Adobe reader is like on windows - only a few things can be done.
I personally thin the free version of Master PDF editor (version 4) is the best that I have encountered, but there are quite a few out there. And there are other tools that can make up for any of its shortcomings. ( probably not 'keeping your last location' though. )
dotw
#6 Post by dotw »
CharlesV wrote: Mon Feb 05, 2024 10:17 pm Both are available for linux, however as I recall the Adobe reader is like on windows - only a few things can be done.
i tried the flatpak version of adobe acrobat but it can only open pdf files; i cannot annotate anything like highlight or underline. The linux edition of foxit is very buggy - I open a pdf file and it crashes after a few minutes. Also it has not been updated since 2017
CharlesV
#7 Post by CharlesV »
Ayup, this is why I like Master PDF editor - for me, this is the best I have found.
CharlesV
#8 Post by CharlesV »
If you change the settings in Master PDF editor, to save History (Restore last location and restore last view) .. then just close the app where you are - and open the app (NOT open the PDF!) , then it will take you immediately to where you were.
CharlesV
#9 Post by CharlesV »
For the copying issue - two things I can think of.
First, you can insert the entire pdf your working on, and then rearrange it. ( ie multiple copy ) or,
second use PDF Arranger.. it can do some pretty cool things.
dotw
#10 Post by dotw »
CharlesV wrote: Mon Feb 05, 2024 10:28 pm For the copying issue - two things I can think of.
i meant copying texts from the PDF document and not the document itself
