Buster+Kde+Bare-Bones+2020.1
Posted: Thu Jan 02, 2020 12:21 am
by jackdanielsesq
Buster+Kde+Bare-Bones+2020.1.iso
Happy New 2020, y'all ... :happybday:
Buster+Kde+Bare-Bones+2020 is a real fast beautiful standalone Respin
It-Is-Bullet-Proof - we tried to break it - we could not - it has, we believe, quite frankly, overtaken MX-18, in a very, very short time span Kudos To The Developers - they did a magnificent job in a very short time.
Despite Igor's protestations!! Plus its only 1.1GB
This is our 1st Respin of Bare-Bones-Kde using an excellent, stable rebuild of MX19[BUSTER] as a base – this baby is equally as lean & mean as the previous rebuilds - it contains the basic OS, including a bunch of great MX Tools, as well as Audacious Music Player .. everything works, as advertised
There are so many choices in the various repos, that we decided to strip everything out, let the owner decide which browser - there are 11x browsers to choose from, with Konqueror already installed, plus there are 5x repos, several email client, 10x office applications, another 10x kernels to choose from, plus tons of games + Steam, etc .. the list goes on. plus its all Up-To-Date as of Jan 1st 2020 .. the choices are mind-boggling
Tap your mouse wheel, and roll it .. KDE is active, so is the music – as before the 'jack' a/c is already activated – same with Audacious – simply adjust volume sliders, etc....enjoy CSN&Y
Y'all might want to use this iso as a base for building your very own O/S
There are oodles of great apps to choose from - check MX Tools, MX Package Installer, browse thru everything
Once again - kudos to the A Team - the best Dev Team in the World .. :number1:
Highest Regards
Jack
PS - its the iso with '2020' in it
https://sourceforge.net/projects/mx-kde-iso/files/
Re: Buster+Kde+Bare-Bones+2020.1
Posted: Thu Jan 02, 2020 2:49 am
When I have the time, I'll check this one out.
Posted: Thu Jan 02, 2020 7:22 am
Hello jackdanielsesq
Simply smashing!
installed with start to a log-in window for the new user and passwords. where does sddm fit in?
Y'All are going to love this. The jack account settings, wow. Sending from Konqueror.
Info:      Processes: 159 Uptime: 5m Memory: 1.94 GiB used: 596.4 MiB (30.0%) Init: SysVinit v: 2.93 runlevel: 5 default: 5
           Compilers: gcc: 8.3.0 alt: 8 Shell: bash v: 5.0.3 running in: konsole inxi: 3.0.36
System:    Host: tubb Kernel: 4.19.0-6-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.14.5 tk: Qt 5.11.3
           wm: kwin_x11 dm: LightDM Distro: MX-19_x64 patito feo October 21  2019 base: Debian GNU/Linux 10 (buster)
herek@tubb:~
Posted: Fri Jan 03, 2020 1:37 am
by jackdanielsesq
Simply smashing!
Thank you .. :celebrate:
KDE logs in automagically - right-click on desktop, hit Settings, hit KDE System Settings, Account User,
User Manager ... add new user, etc
Leave jack in-situ .. good backup should you wreck your new user, or get locked out of of Plasma
New user would have zero gingerbread - have fun
We have never been able to break KDE on MX18/19 ... again, Kudos to the Dev Team .. :number1:
Cannot say the say for other O/S, even Debian respins/rebuilds/remixes
sudo minstall
jack/jack
root/root
Enjoy
Highest Regards
Jack
Posted: Fri Jan 03, 2020 1:45 am
by jackdanielsesq
Greetings Asqwerth,
Would consider that an absolute compliment - thank you .. :crossfingers:
Its because of the sheer-genius, and due-diligence of the Developers Team, that us
mere mortals get to mess around, have a lot of fun - again, a very big thank you
Highest Regards
Jack
asqwerth wrote: Thu Jan 02, 2020 2:49 am When I have the time, I'll check this one out.
Posted: Sun Jan 05, 2020 10:50 am
by mmontz
Is there something that needs to be done to enable wireless network? If not, then it is not working.
Regards,
Michael
Posted: Sun Jan 05, 2020 12:04 pm
by rasat
Added in MX Desktop Respins (list).
viewtopic.php?f=100&t=48617
Posted: Tue Jan 07, 2020 4:51 pm
by Grover
No WiFi here, either. Any ideas how to fix it?
Otherwise, it looks promising.
Posted: Thu Jan 09, 2020 4:30 am
by rasat
When I changed from Xfce to Gnome had same problem. It was solved with network-manager and firmware... packages (don't remember which one).
Posted: Wed Mar 25, 2020 3:49 pm
by MAYBL8
Your iso won't boot for me.
I think my problem is this:
viewtopic.php?f=92&t=54355
