MX-18 beta 1 feedback
#1 Post by dolphin_oracle »
Place feedback from the MX-18 beta 1 testing iso here.
If posting hardware issues, please post the output of the terminal command "inxi -F" or use our "Quick-system-info" from the menu, at a minimum.
If posting nvidia-installer issues, please post the contents of /var/log/ddm.log.
If posting remaster issues, please include the contents of /var/log/live/live-remaster.log
If posting issues with MX-PackeageInstaller "Popular Apps", please post contents of /var/log/mxpi.log or /var/log/mxpi.log.old (whichever contains the log of your issue).
PPC
Re: MX-18 beta 1 feedback
#2 Post by PPC »
dolphin_oracle wrote: Mon Dec 03, 2018 6:45 am Place feedback from the MX-18 beta 1 testing iso here.
Hi.
The only real "problem" I had with MX 17 was installing the nvidea driver. My MX box is my work pc, so if I test it, it's via live USB... Is there a way of installing the driver on it? with/without activating persistency?
P.
#3 Post by dolphin_oracle »
PPC wrote: Mon Dec 03, 2018 7:09 am
Hi.
P.
no, not really. they will install, but there seems to be issues with getting them working on a live system.
and please check the "known issues" on the beta 1 - nvidia driver install from the main repos may not install yet. those from debian-backports should, and we will have new ones in the main repo before final release.
#4 Post by richb »
Installed on ssd, no encryption, full disk. Configured to my preferences in about 10 minutes including adding Google Chrome and GC extensions. Looking good.
Paul..
#5 Post by Paul.. »
Installed on nvme, no encryption, nvme0n1p2...went smoothly but 'nVidia driver installation' failed with dependency problems both on Main and Backports option:
 libnvidia-encode1 : Depends: libcuda1 (= 384.130-1) but it is not going to be installed
                     Depends: libnvcuvid1 (>= 260) but it is not going to be installed
 nvidia-driver : Depends: nvidia-driver-libs (= 384.130-1) but it is not going to be installed or
                          nvidia-driver-libs-nonglvnd (= 384.130-1) but it is not going to be installed
                 Depends: nvidia-driver-bin (= 384.130-1) but it is not going to be installed
                 Depends: xserver-xorg-video-nvidia (= 384.130-1) but it is not going to be installed
                 Depends: nvidia-vdpau-driver (= 384.130-1) but it is not going to be installed
                 Depends: nvidia-alternative (= 384.130-1)
                 Recommends: nvidia-persistenced
 nvidia-kernel-dkms : Depends: nvidia-kernel-support--v1
 nvidia-settings : Depends: nvidia-alternative
                   Depends: libxnvctrl0 (= 384.111-1~deb9u1) but 390.67-1~mx17+1 is to be installed
                   Recommends: libgl1-nvidia-glvnd-glx but it is not going to be installed or
                               libgl1-nvidia-glx but it is not going to be installed
                   Recommends: nvidia-vdpau-driver but it is not going to be installed
                   Recommends: libnvidia-ml1 but it is not going to be installed
/usr/local/bin/ddm-mx: line 472: creating /etc/X11/xorg.conf file: No such file or directory
/usr/local/bin/ddm-mx: line 473: nvidia-xconfig: command not found
Finished
New Rig:
System:    Host: XXXXXX Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
           Desktop: Xfce 4.12.3 Distro: MX-18b1_x64 Continuum December 3  2018
Machine:   Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x serial: <filter>
           UEFI: American Megatrends v: 4011 date: 04/19/2018
CPU:       Topology: Quad Core model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen rev: 1
           L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 51097
           Speed: 2054 MHz min/max: 1550/3200 MHz Core speeds (MHz): 1: 1537 2: 1471 3: 1367
           4: 1375 5: 1854 6: 2090 7: 2266 8: 2225
Graphics:  Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] driver: nouveau v: kernel bus ID: 09:00.0
           Display: x11 server: X.Org 1.19.2 driver: nouveau unloaded: fbdev,modesetting,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: NV117 v: 4.3 Mesa 18.2.6 direct render: Yes
Audio:     Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 09:00.1
           Device-2: AMD driver: snd_hda_intel v: kernel bus ID: 0b:00.3
Network:   Device-1: Intel I211 Gigabit Network driver: igb v: 5.4.0-k port: e000
           bus ID: 07:00.0
Drives:    Local Storage: total: 698.65 GiB used: 147.41 GiB (21.1%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB size: 232.89 GiB
           ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
Partition: ID-1: / size: 47.81 GiB used: 5.47 GiB (11.4%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: swap-1 size: 15.62 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p5
Sensors:   System Temperatures: cpu: 31.9 C mobo: N/A gpu: nouveau temp: 33 C
           Fan Speeds (RPM): cpu: 0 gpu: nouveau fan: 1080
           1: deb http://mirrors.rit.edu/mxlinux/mx-packages/antix/stretch/ stretch main
           1: deb http://mirrors.rit.edu/mxlinux/mx-packages/mx/repo/ stretch main non-free
Info:      Processes: 295 Uptime: 43m Memory: 15.66 GiB used: 3.31 GiB (21.1%) Init: SysVinit
           runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.25
Samsung 860 500GB SSDs (2)
Gerson
#6 Post by Gerson »
I installed the beta MX-18 on the installation of MX-17.1 keeping only the /home, it took 11 minutes and it works fine.
I did not like the Plymouth they chose and I have a doubt about the last item in the choice of partitions. I do not know what to place if MX is the only system I use.
It's something new for me, the "boot".
#7 Post by richb »
You can choose a different Plymouth splash screen with MX Boot Options. As I am sure you can appreciate tastes vary and all cannot be pleased. That is why an option is provided.
chrispop99
#8 Post by chrispop99 »
Currently, Package Installer>Popular Applications tab does not show currently installed kernel.
(I understand why, but users used to seeing it there might not.)
DELL XPS 15
Lots of test machines
Eadwine Rose
#9 Post by Eadwine Rose »
Tried installing Nvidia using the MX setup option.
Haven't done anything else yet, not even reloaded synaptic or anything. Only disabled the splash screen and set things to very detailed.
About to execute /usr/local/bin/ddm-mx -i nvidia.
This command needs root privileges to be executed.
Using su...
Enter root password at prompt.
Password:
creating lock ...
Install drivers for: nvidia
Start at (m/d/y): 12/03/2018 15:57:29
Candidate is:  384.130-1
Installed is:  (none)
Would you like to check debian-backports for a later version?
Yes or No?
1: Yes
2: No
Enter Number of selection
2
Ok...
Need driver: nvidia-driver (384.130-1)
 packages to install are  nvidia-driver nvidia-settings nvidia-kernel-dkms libnvidia-encode1 nvidia-xconfig
Continue?
  1) yes (default)
  2) no
Press <Enter> for the default entry
Use 'q' to quit
1
Frontend:
Nvidia command  = apt-get install --reinstall -y --force-yes   nvidia-driver nvidia-settings nvidia-kernel-dkms libnvidia-encode1 nvidia-xconfig
Reading package lists...
Building dependency tree...
Reading state information...
Reinstallation of linux-headers-4.19.0-1-amd64 is not possible, it cannot be downloaded.
        Reinstallation of firmware-linux-nonfree is not possible, it cannot be downloaded.
        0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 1 not upgraded.
                                               Need to get 0 B/7,346 B of archives.
        After this operation, 0 B of additional disk space will be used.
(Reading database ... 324469 files and directories currently installed.)
Preparing to unpack .../build-essential_12.3_amd64.deb ...
Unpacking build-essential (12.3) over (12.3) ...
Setting up build-essential (12.3) ...
Finished
Press <Enter> to exit
MX-23.6_x64 July 31 2023 * 6.1.0-40amd64 ext4 Xfce 4.20.0 * 8-core AMD Ryzen 7 2700
Eadwine Rose
#10 Post by Eadwine Rose »
Second try, attempting backports and installing that...
Using su...
Password:
creating lock ...
Start at (m/d/y): 12/03/2018 16:02:15
Yes or No?
1: Yes
2: No
1
Ok...
Enabling backports repo
Running apt-get update...
Hit:1 http://ftp.nl.debian.org/debian stretch-updates InRelease
Hit:2 http://nl.mxrepo.com/antix/stretch stretch InRelease
Hit:3 http://nl.mxrepo.com/mx/repo stretch InRelease
Get:4 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Ign:5 http://ftp.nl.debian.org/debian stretch InRelease
Hit:6 http://ftp.nl.debian.org/debian stretch Release
Hit:7 http://security-cdn.debian.org stretch/updates InRelease
Get:8 http://ftp.debian.org/debian stretch-backports/main i386 Packages [509 kB]
Get:9 http://ftp.debian.org/debian stretch-backports/main amd64 Packages [515 kB]
Get:10 http://ftp.debian.org/debian stretch-backports/main Translation-en [393 kB]
Get:11 http://ftp.debian.org/debian stretch-backports/contrib i386 Packages [7,252 B]
Get:12 http://ftp.debian.org/debian stretch-backports/contrib amd64 Packages [7,620 B]
Get:13 http://ftp.debian.org/debian stretch-backports/contrib Translation-en [6,233 B]
Get:14 http://ftp.debian.org/debian stretch-backports/non-free amd64 Packages [29.1 kB]
Get:15 http://ftp.debian.org/debian stretch-backports/non-free i386 Packages [19.4 kB]
Get:16 http://ftp.debian.org/debian stretch-backports/non-free Translation-en [33.8 kB]
Fetched 1,611 kB in 1s (1,161 kB/s)
Installing latest nvidia-detect package
  nvidia-detect
1 upgraded, 0 newly installed, 0 to remove and 119 not upgraded.
Need to get 193 kB of archives.
Get:1 http://ftp.debian.org/debian stretch-backports/non-free amd64 nvidia-detect amd64 390.87-2~bpo9+1 [193 kB]
Fetched 193 kB in 0s (3,056 kB/s)
Preparing to unpack .../nvidia-detect_390.87-2~bpo9+1_amd64.deb ...
Unpacking nvidia-detect (390.87-2~bpo9+1) over (390.87-2~bpo9+1~mx17+2) ...
Setting up nvidia-detect (390.87-2~bpo9+1) ...
Main repo candidate is:   384.130-1
Debian backports candidate is:   390.87-2~bpo9+1
Which driver do you wish to install
Main repos or debian-backports?
1: Main 384.130-1
2: debian-backports 390.87-2~bpo9+1
3: Exit
2
Ok...
Need driver: nvidia-driver (390.87-2~bpo9+1)
Continue?
  1) yes (default)
  2) no
Use 'q' to quit
1
Frontend:
Nvidia command  = apt-get install --reinstall -y --force-yes -t stretch-backports nvidia-driver nvidia-settings nvidia-kernel-dkms libnvidia-encode1 nvidia-xconfig
 nvidia-settings : Depends: libxnvctrl0 (= 390.48-2~bpo9+1) but 390.67-1~mx17+1 is to be installed
Finished
Hit:1 http://nl.mxrepo.com/antix/stretch stretch InRelease
Hit:2 http://nl.mxrepo.com/mx/repo stretch InRelease
Hit:3 http://ftp.nl.debian.org/debian stretch-updates InRelease
Ign:4 http://ftp.nl.debian.org/debian stretch InRelease
Hit:5 http://security-cdn.debian.org stretch/updates InRelease
Reading package lists... Done
Nope... trying that bit again and then keeping the version 384..
Hmm wait.. nvidia detect is already at that latest 390 one.. rebooting and see...
Nope, no such luck:
System:    Host: mx18b1 Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Machine:   Type: Desktop Mobo: ASUSTeK model: M4A785TD-V EVO v: Rev X.0x serial: <filter>
           BIOS: American Megatrends v: 2005 date: 04/15/2010
Battery:   Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
           charge: Normal status: Discharging
CPU:       Topology: Quad Core model: AMD Athlon II X4 635 bits: 64 type: MCP arch: K10 rev: 3
           L2 cache: 2048 KiB
           flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 23304
           Speed: 800 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 800 2: 800 3: 2900 4: 2900
Graphics:  Device-1: NVIDIA GK208 [GeForce GT 640 Rev. 2] driver: nouveau v: kernel
           bus ID: 01:00.0
           OpenGL: renderer: NV108 v: 4.3 Mesa 18.2.6 direct render: Yes
Audio:     Device-1: AMD SBx00 Azalia driver: snd_hda_intel v: kernel bus ID: 00:14.2
           Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
           Device-3: Brooktree Bt878 Video Capture driver: bttv v: 0.9.19 bus ID: 03:06.0
           Device-4: Brooktree Bt878 Audio Capture driver: snd_bt87x v: kernel bus ID: 03:06.1
           Device-5: Logitech QuickCam E 3500 type: USB driver: snd-usb-audio,uvcvideo
           bus ID: 1-1:2
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           v: kernel port: d800 bus ID: 02:00.0
           Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus ID: 2-2:3
Drives:    Local Storage: total: 1.37 TiB used: 4.87 GiB (0.3%)
           ID-1: /dev/sda vendor: Hitachi model: HDP725050GLA360 size: 465.76 GiB
           ID-2: /dev/sdb type: USB vendor: Western Digital model: WD My Passport 25E1
           ID-3: /dev/sdc type: USB model: USB DISK 2.0 size: 3.73 GiB
Partition: ID-1: / size: 455.45 GiB used: 4.87 GiB (1.1%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 22.5 C mobo: N/A gpu: nouveau temp: 36 C
           1: deb http://nl.mxrepo.com/antix/stretch stretch main
           1: deb http://ftp.nl.debian.org/debian/ stretch-updates main contrib non-free
           1: deb http://ftp.nl.debian.org/debian/ stretch main contrib non-free
           1: deb http://nl.mxrepo.com/mx/repo/ stretch main non-free
Info:      Processes: 201 Uptime: 1m Memory: 7.79 GiB used: 452.4 MiB (5.7%) Init: SysVinit
Nope..
Using su...
Password:
creating lock ...
Start at (m/d/y): 12/03/2018 16:09:08
Yes or No?
1: Yes
2: No
1
Ok...
Get:3 http://ftp.debian.org/debian stretch-backports InRelease [91.8 kB]
Hit:4 http://ftp.nl.debian.org/debian stretch-updates InRelease
Fetched 1,611 kB in 1s (1,146 kB/s)
nvidia-detect is already the newest version (390.87-2~bpo9+1).
0 upgraded, 0 newly installed, 0 to remove and 119 not upgraded.
1: Main 384.130-1
3: Exit
1
Ok...
Continue?
  1) yes (default)
  2) no
Use 'q' to quit
Frontend:
Finished
Hit:5 http://ftp.nl.debian.org/debian stretch Release
Hit:6 http://security-cdn.debian.org stretch/updates InRelease
Let's see what synaptic is saying about those broken things..
nothing except mx welcome that can be upgraded.
Color me confused.
Going back to my 17.1 install now.. I gots other stuff to do ;)
Locked
