[SOLVED] MX-17 package update request: Xfburn
I have been advised to use Xfburn instead of Brasero (https://forum.mxlinux.org/viewtopic.php ... 08#p455808).
Unfortunately using Xfburn's 0.5.4 version that ships with MX-17 (from Debian) is extremely difficult for me: Xfburn's window is about twice as wide as my acual screen, and the window can't be rescaled. This is the only application that has shown this kind of behaviour so far.
The most current stable version of Xfburn seems to be 0.5.5. According to this changelog: https://launchpad.net/ubuntu/+source/xfburn/0.5.5-1, "some fixes for the desktop file" have been implemented there, so maybe that fixes the problem.
I see that 0.5.5 is available in Debian Sid (https://packages.debian.org/en/sid/xfce/xfburn). Could you possibly provide it in the MX Test Repo?
Greetings, and thanks so much in advance for looking into this, Joe
- chrispop99
- Global Moderator
Re: MX-17 package update request: Xfburn
Might it be better to try to fix the re-sizing problem first; it's possible it may still happen with the updated version?
Xfburn has never exhibited that behaviour here when testing, although on my everyday machine I use K3B.
DELL XPS 15
Lots of test machines
DELL XPS 15
Seems to be a translation-string related issue with to long translated / unwrapped strings.MX-16_fan wrote: Fri Jul 27, 2018 11:02 am ...
Please try to use default build in locale (english)
by starting from the cli or by adjusting the desktop starter accordingly
like this:
env LANG=C xfburn
@fehlix:
Is that an error in the 0.5.4 source code?
Greetings, Joe
Thanks for the workaround. With that I get a normal width.fehlix wrote: Fri Jul 27, 2018 12:07 pm (...)
like this:Code: Select all
env LANG=C xfburn
Greetings, Joe
I would flag it a an translation code error, as the translation string missing line feeds for line wrappings.MX-16_fan wrote: Fri Jul 27, 2018 12:51 pm @fehlix:
env LANG=C xfburn
Greetings, Joe
So in this sense as the translation strings are part of the souce code package you can regard it as a source code "bug"
That's something which we should be able to fix in a patch for the affected translation file if necessary. I'll backport 5.5 to see if they've fixed it, and if not, we can work to fix the string in the localization source file...though upstream should also be notified of the bug. Is it in the "de" locale?
@Stevo:
Greetings, and have a great weekend, Joe
Thanks!Stevo wrote: Fri Jul 27, 2018 2:13 pm That's something which we should be able to fix in a patch for the affected translation file if necessary. I'll backport 5.5 to see if they've fixed it, and if not, we can work to fix the string in the localization source file...though upstream should also be notified of the bug.
Yes.
I can't see any fix Debian added for the 0.5.5 version, no Debian bug reports for the issue: https://bugs.debian.org/cgi-bin/pkgrepo ... t=unstable and there's no change at all in the de translation source file between 0.5.4 and 0.5.5. I can see some sections where it looks like the de translation strings are missing the returns, so I'll try and fix those.
Changing the strings below within xfburn.mo for locale DEStevo wrote: Fri Jul 27, 2018 3:21 pm I can't see any fix Debian added for the 0.5.5 version, no Debian bug reports for the issue: https://bugs.debian.org/cgi-bin/pkgrepo ... t=unstable and there's no change at all in the de translation source file between 0.5.4 and 0.5.5. I can see some sections where it looks like the de translation strings are missing the returns, so I'll try and fix those.
--- xfburn.po.orig 2018-07-27 20:54:43.579202403 +0200
+++ xfburn.po 2018-07-27 21:44:02.265074643 +0200
@@ -162,7 +162,7 @@
msgstr "Künstler"
msgid "Audio CD playable in regular stereos"
-msgstr "Eine Musik-CD zum Abspielen in normalen Stereoanlagen erstellen"
+msgstr "Eine Musik-CD zum Abspielen\nin normalen Stereoanlagen erstellen"
msgid "Audio composition"
msgstr "Musikzusammenstellung"
@@ -195,7 +195,7 @@
msgstr "CD-Abbild brennen (xfburn)"
msgid "Burn a prepared compilation, i.e. an .ISO file"
-msgstr "Zusammenstellung brennen (z.B. ISO-Dateien)"
+msgstr "Zusammenstellung brennen\n (z.B. ISO-Dateien)"
msgid "Burn image"
msgstr "Abbild brennen"
@@ -360,7 +360,7 @@
msgstr "ISO aus CD erzeugen"
msgid "Create a new data disc with the files of your choosing"
-msgstr "Ein neues Datenmedium mit beliebigen Dateien erstellen"
+msgstr "Ein neues Datenmedium\nmit beliebigen Dateien erstellen"
msgid "Create directory"
msgstr "Neuer Ordner"
@@ -667,7 +667,7 @@
msgid "Prepare the rewriteable disc for a new burn"
msgstr ""
-"Ein wiederbeschreibbares (RW) Medium für einen neuen Brennvorgang vorbereiten"
+"Ein wiederbeschreibbares (RW) Medium\nfür einen neuen Brennvorgang vorbereiten"
msgid "Proceed to Burn"
msgstr "Weiter zum Brennen"
Hmmm...I did a bigger set of changes.
Does this version fix it?
https://drive.google.com/open?id=1FxCv9 ... 4KnDGr7WWJ
