MX 17/18 Repository: The qBittorrent Thread
#1 Post by Stevo »
We now have the latest qBittorrent 4.0.2 in our test repository. It's built against libraries already available in standard MX 17, making it simple to move to main after testing. This is a major update from our last 3.3.16 version; the large number of changes and fixes can be seen here. It is not feasible to build it on a MX 15/16 platform any longer without a major update of Qt 5 to at least 5.5.1, so that's very probably not going to happen, so future updates will be restricted to MX 17.
This is probably the best Linux Bittorrent program available, and we'd appreciate feedback from testers so we can move it to main.
Re: MX 17 Repository: The qBittorrent Thread
#2 Post by Jerry3904 »
Installed fine on MX-17 B3, insertion in menu good, launches, fires up correctly when a torrent is clicked, downloading proceeding now.
mmikeinsantarosa
#3 Post by mmikeinsantarosa »
qbittorrent-4.0.3 is now available to upgrade to.
What's new:
Some more bugs fixed.
macOS builds are available now too. Check the 4.0.0 changelog for the macOS specific new features.
v4.0.3 changelog:
BUGFIX: Add height padding to the transfer list icons. Closes #7951. (sledgehammer999)
BUGFIX: Allow to drag-n-drop URLs into mainwindow to initiate download. (Chocobo1)
BUGFIX: Fix crash when fitlering search results. Stable sorting is removed. Closes #7952.(Chocobo1)
WEBUI: Fix missing qbt logo on login page in webUI. Closes #7953. (Chocobo1)
WEBUI: Add check to avoid type error after logout. (Chocobo1)
WEBUI: Use POST for logout command. This is to avoid browser being smart to prefetch the link then logging out the user. (Chocobo1)
WEBUI: Fix WebUI is not reachable via IPv6. (glassez)
WINDOWS: Disable the "?" help button in all dialogs on Windows. Closes #7365. Requires Qt 5.10. (Chocobo1)
Feel free to post any testing results here. - mike
#4 Post by Stevo »
The latest release, 4.0.4, is now in the test repository. It is built against an updated libtorrent-rasterbar 1.1.5, which is also in the test repo and will be pulled in automatically. Changes can be viewed here.
Gordon Cooper
#5 Post by Gordon Cooper »
4.0.4 installed and running. So far no problems encountered.
#6 Post by Stevo »
We now have qBittorrent 4.1.0 in the test repo. This is a major new release, so check out the release notes here and let us know how it's working.
Gordon Cooper
#7 Post by Gordon Cooper »
4.1.0 installed and running OK. Have not yet checked any of the fixes or improvements, will leave it running (as usual) and see if any glitches show up. The number
of users downloading has dropped off, as might be expected. 64 bit MX continues to be the most popular and there's an occasional burst of activity downloading antiX.
bwhawk
#8 Post by bwhawk »
I installed 4.10 and downloaded a torrent. No problems encountered so far, but I can't claim to be a heavy user.
Richard
#9 Post by Richard »
Installed 4.10.
Seems much more complete and configurable.
Looking for something to download.
__kernal 5.10.0-26-amd64 x86_64; Xfce-4.18.0; 8 GB RAM
__Intel Core i5-3380M, Graphics, Audio, Video; & SSDs.
HP Ryzen 5 17-cp3xxx with MX23.4 AHS & Liquorix 6.10-12~mx23ahs amd64
#10 Post by Stevo »
We now have the latest 4.1.1 release in the test repo, along with the updated libtorrent-rasterbar-1.1.7+yada-yada-yada that was recommended. Please let us know how it's installing and working if you try it out. Thanks!
Locked
