MX-17 Beta 2 Feedback
mmontz
Re: MX-17 Beta 2 Feedback
#241 Post by mmontz »
You have to sign with a VPN provider. In this case it is Private Internet Access. Cost is about $40.00/yr.
#242 Post by Jerry3904 »
danielson wrote:Btw, don't know who to thank for the desktop backgrounds (especially the wavy curtain kind) but they are just superb!
Hope to see more colors of same pattern.
Thanks for the kind words. We actually have a blog post on the topic:
https://mxlinux.org/mx17-artwork-prettifying-our-distro
Personal: MX-25 Fluxbox, ThinkPad X1 Carbon gen 9 with i7
danielson
#243 Post by danielson »
Logitech headset issues again...
No matter how many times select the headset as default via MX-Select Sound or Alsa, the choice is not "sticking".
Have updated system and rebooted twice already (just in case).
@Jerry3904 - thank you for the link! Must write a word of appreciation to antechdesigns!
#244 Post by dolphin_oracle »
danielson wrote:Logitech headset issues again...
do you unplug the headset?
I would set it as the default sound sink in pavucontrol rather than trying to set it via alsa. (which is what set-sound-card will try to do).
#245 Post by richb »
mmontz wrote:You have to sign with a VPN provider. In this case it is Private Internet Access. Cost is about $40.00/yr.
Thanks. Up and running. Download speed is about 60% of a normal connection, upload about 90%. But very usable.
danielson
#246 Post by danielson »
@dolphin_oracle,
Logitech is usually always plugged in.
Have removed it a few times to see, still no go.
Usually managed to get volume controls going with the Logitech device itself but no config options in pulseaudio controls are not doing it.
Update: got it! via alsa icon on panel (not alsa mixer).
dr-kart
#247 Post by dr-kart »
I tried to install oracle java 9. http://www.webupd8.org/2015/02/install- ... linux.html
(I did this way with mx 16.1 with no issues)
Now installation went without any warnings. And I do have
java -version
java version "9.0.1"
Java(TM) SE Runtime Environment (build 9.0.1+11)
Java HotSpot(TM) 64-Bit Server VM (build 9.0.1+11, mixed mode)
But neither Firefox ESR nor Palemoon locate java plug-in. Which was the case with mx16.1.
Still not sure if this relates to current mx17b2. Did anyone have an experience installing java9 ?
stsoh
#248 Post by stsoh »
hi,
btrfs auto resume lengthen boot time by 27sec, is this necessary? can it be not resume?
i like the fast boot time of mx-linux but fall short when i saw during bootup started to resume btrfs scripts/local-block 27 times.
anyway, i googled n found a solution to stop btrfs resume function.
adding a new line containing "RESUME=none" to the end of /etc/initramfs-tools/initramfs.conf.
followed up, open terminal > su > password and run "update-initramfs -u".
See "man initramfs.conf" for details.
MX-16_fan
#249 Post by MX-16_fan »
I have a very cool super small no-name USB Nano stick here. Tested the MX-17 Beta 2 Live, and it managed to work with it on approx. every second boot (couldn't find any logic in it). Sometimes I had to unplug and replug it, and only after that it was being discovered.
However, when I used a fully installed MX-17 Beta 2, the stick wasn't being discovered at all.
On a different machine, lsusb identifies this WiFi stick as
Bus 001 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Doing a full dist-upgrade, taking everything that's in the MX Test Repo, didn't bring any change.
I had sometimes-but-sometimes-not kind of trouble using this stick with MX-16.1 also.
Ethernet isn't always present either.
Greetings, Joe
BitJam
#250 Post by BitJam »
MX-16_fan wrote:I have a very cool super small no-name USB Nano stick here. Tested the MX-17 Beta 2 Live, and it managed to work with it on approx. every second boot (couldn't find any logic in it). Sometimes I had to unplug and replug it, and only after that it was being discovered.
I've had that problem with SanDisk Ultra-Fit usb 3 sticks. They would always boot if I unplugged and replugged them while it was looking for the linuxfs file. I could not find a way to fix it. I think it is a problem with the hardware and/or the kernel. I've stopped using them as live-usbs. I now use Samsung Flash drive Fit usb-3 sticks. I don't have this problem with them or with any of the other usb sticks I've tried.
-- Richard Feynman
Locked
