Different package name for Pale Moon AVX?
seriousness
#1 Post by seriousness »
Hello, hope this is the right forum for my question:
every time a new version is available, it wants to replace the installed AVX build from test with the SSE2 one on updating.
Would it be possible to give the packages different names to prevent this?
Re: Different package name for Pale Moon AVX?
#2 Post by Stevo »
We are putting the AVX version in the test repo for now to keep it separate. Just refuse the regular upgrade and use MXPI to install the test repo version instead.
MXPI = MX Package Installer
QSI = Quick System Info from menu
The MX Test repository is mostly backports; not the same as Debian testing
#3 Post by fehlix »
seriousness wrote: Sun Apr 13, 2025 4:26 am Hello, hope this is the right forum for my question:
Jost hold the one you want to get not upgrade with
sudo apt-mark hold palemoon
It will be shown as kept back package.
seriousness
#4 Post by seriousness »
Thanks, I know how to work around this; it's just somewhat inconvenient...
#5 Post by fehlix »
seriousness wrote: Sun Apr 13, 2025 11:34 am Thanks, I know how to work around this; it's just somewhat inconvenient...
That's good. This is the way apt works, the latest (highest) version will be selected as installation candidate. Either set to hold current, or set a PIN priority accordingly to convince apt to keep a lower version.
#6 Post by Stevo »
I think it's a better idea to get the updated browser with bugfixes, even if the first install will be non-AVX. Can you really tell if it's much slower?
Pale Moon is also really protective of its name, I don't want to go changing it right off.
seriousness
#7 Post by seriousness »
I notice a slight improvement, but this could also be homeopathic...
Firefox and Vivaldi perform better without demanding for AVX.
jeffreyC
#8 Post by jeffreyC »
Stevo wrote: Sun Apr 13, 2025 7:03 pm I think it's a better idea to get the updated browser with bugfixes, even if the first install will be non-AVX. Can you really tell if it's much slower?
Would they object to palemoon-avx as a name though?
It might be worth asking on their forum.
#9 Post by Stevo »
Since the "palemoons" they provide are all avx already, I can see how they might object to that.
Return to “Package Requests - MX-23”
