too many wine issues/how fix 32-bit dependencies?
autumn
#1 Post by autumn »
Hello
Was only recently I've tried out some games, after getting new pc early January. Lack of 32-bit wine dependencies is causing too many issues, with both art and games and generally. Add into that wine not seeming to see that I have the right things installed, and too much now locked behind root, system is not able to be used normally.
For example, an issue with Krita at this time, so fired up Sai2, which I have full proof of purchase for btw. Sai2 never had issues before this new pc/6.1 kernel/wine 8.0. Now 'memory insufficient', so saving breaks after a while, in just a minute or two if try liquorix 6.6 kernel. Lost work. Also 'windows function call failed', and a solution I saw online referenced that their virus protector had decided to block Sai2 from changing a file type ... why would I get a similar issue on Linux? Too much is locked behind things now; it's unnecessary and obstructive. Unlike pre-kernel6.1/wine8, had to go into root to apply dark theme to Sai2 is just one example. Shim error reading root, even during installing wine, is another. Many more similar things have occurred e.g. constantly can't open txt files directly with geany or open things from microSD backups, etc.
About games, I don't know where to start, but will try to summarise. I have everything correctly installed, including winetricks and the installs via that, including dxvk if needed, same as before. Just cannot run backed up games eg gog. I don't use steam or go online, same as before this new pc. Same games, same setup, but everything's broken.
Tried lots and these are the errors that come up:
0024:err:vulkan:wine_vk_init Failed to load libvulkan.so.1.
0024:err:wgl:init_opengl Failed to load libGL: libGL.so.1: cannot open shared object file: No such file or directory
0024:err:wgl:init_opengl OpenGL support is disabled.
0024:err:d3d:wined3d_caps_gl_ctx_create Failed to find a suitable pixel format.
0024:err:d3d:wined3d_adapter_gl_init Failed to get a GL context for adapter 047EE3D8.
yet, locate libGL.so.1 ...
/usr/lib/x86_64-linux-gnu/libGL.so.1
/usr/lib/x86_64-linux-gnu/libGL.so.1.7.0
and
glxinfo | grep "OpenGL version" ...
OpenGL version string: 4.6 (Compatibility Profile) Mesa 24.2.8-1~bpo12+1
Failed to initialize graphics.
Make sure you have DirectX 11 installed, have up to date
drivers for your graphics card and have not disabled
3D acceleration in display settings.
InitializeEngineGraphics failed
not possible to create direct3d rendering device. you may need to reinstall directx and/or update drivers for your graphic card.
Any solution I've read, for days, has concerned me, especially as I have all these things in place (except 32-bit stuff):
If you're running a 32-bit app, you also need the 32-bit GL drivers. You'll need to search for how to install 32-bit OpenGL libs on a 64-bit system.
Did you set the wined3d renderer to vulkan? Because your wine doesn't have vulkan support.
Looks like you are missing 3d acceleration. What gfx card do you have, and what drivers are you running?
"It's failing to load your libGL.so, do you have your graphics driver properly installed (both 32bit and 64bit)?"
Every other 'solution' references proton, but I'm offline, just trying to run normal wine.
Why is nothing being seen? How is it possible to fix 32-bit dependencies? And freeing up things from overzealous root would no doubt help too. I could add all kinds of code output from every error and showing everything needed is installed, but will just add quick info unless other stuff is requested. Would really appreciate especially knowing how to find the 32-bit dependencies, as lack of those seems to be having a very detrimental effect on running things, now I've got round to trying things out. Didn't want to upgrade pc or go onto the 6 kernel series or upgrade wine in the first place. Would be very grateful if there's any solution to this mess.
Snapshot created on: 20250305_1822
  Kernel: 6.1.0-28-amd64 [6.1.119-1] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/vmlinuz-6.1.0-28-amd64 root=UUID=<filter> ro quiet splash
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7 dm: LightDM v: 1.26.0
    Distro: MX-23.4_x64 Libretto December 15 2024 base: Debian GNU/Linux 12 (bookworm)
  Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
  Mobo: ASUSTeK model: PRIME A620M-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2613 date: 04/12/2024
  Info: model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check
    built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
    microcode: 0xA601206
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3026 high: 3599 min/max: 3000/5388 boost: enabled scaling:
    driver: acpi-cpufreq governor: ondemand cores: 1: 3000 2: 3000 3: 3000 4: 3000 5: 3000 6: 2998
    7: 2980 8: 3000 9: 3000 10: 3000 11: 2993 12: 3599 13: 2932 14: 3000 15: 2920 16: 3000
    bogomips: 121593
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  Type: gather_data_sampling status: Not affected
  Type: reg_file_data_sampling status: Not affected
  Type: spec_rstack_overflow mitigation: safe RET
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; STIBP: always-on;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: AMD Navi 33 [Radeon RX 7700S/7600S] vendor: Sapphire driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s
    lanes: 8 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:7480
    class-ID: 0300
  Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: HDMI-A-2 empty: DP-4,DP-5 bus-ID: 0d:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 41.0 C
  Display: x11 server: X.Org v: 1.21.1.7 compositor: marco v: 1.26.1 driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: BenQ LCD serial: <filter>
    built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1-1 pos: right model: AAA built: 2016 res: 1920x1080 hz: 60
    dpi: 85 size: 575x323mm (22.64x12.72") modes: max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 Mesa 24.2.8-1~bpo12+1 renderer: AMD Radeon RX 7600 (radeonsi navi33 LLVM
    15.0.6 DRM 3.49 6.1.0-28-amd64) direct-render: Yes
  Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.0-28-amd64 status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
    chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD Blue SN580 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 281010WD temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 930.25 GiB size: 914.57 GiB (98.31%) used: 173.64 GiB (19.0%) fs: ext4
    dev: /dev/dm-0 maj-min: 253:0 mapped: luks-<filter>
  ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%) used: 210.7 MiB (21.7%) fs: ext4
    dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 274 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2 file: /swap/swap
  System Temperatures: cpu: 51.0 C mobo: N/A
  GPU: device: amdgpu temp: 41.0 C device: amdgpu temp: 36.0 C mem: 34.0 C fan: 0 watts: 4.00
  Packages: pm: dpkg pkgs: 2334 libs: 1163 tools: apt,apt-get,aptitude,nala,synaptic pm: rpm
    pkgs: 0
    1: deb http://mxlinux.mirrors.uk2.net/packages/mx/repo/ bookworm main non-free
  Processes: 367 Uptime: 46m wakeups: 1 Memory: 62.01 GiB used: 2.77 GiB (4.5%) Init: SysVinit
  v: 3.06 runlevel: 5 default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 12
AMD Ryzen 7 7700 8-Core, AMD Radeon RX 7600, 64 ram
MX 23.4, Mate 1.26, kernel 6.1
j2mcgreg
Re: too many wine issues/how fix 32-bit?
#2 Post by j2mcgreg »
I'v read your post three times and I'm confused. Are you trying to run a 32 bit app in a 64 bit operating system?
autumn
#3 Post by autumn »
MY QSI shows a modern 64-bit machine, and from the start my post references missing 32-bit dependencies affecting art and games.
EDIT: added word 'dependencies' into thread title, for anyone not reading the post.
#4 Post by Stevo »
j2mcgreg wrote: Tue Apr 08, 2025 7:00 am I'v read your post three times and I'm confused. Are you trying to run a 32 bit app in a 64 bit operating system?
That's pretty easy with MX's multiarch. I wonder if the OP set up a 32 or 64 bit Wine Environment, though.
MXPI = MX Package Installer
QSI = Quick System Info from menu
The MX Test repository is mostly backports; not the same as Debian testing
autumn
Re: too many wine issues/how fix 32-bit dependencies?
#5 Post by autumn »
Can't make it any clearer guys. Will leave what seems to be gaslighting, intended or otherwise (through just not reading the post), here where it belongs. Have gone to EndeavourOS; 32-bit support, art programmes fine, games running, and not overzealously locked down root, at last.
Eadwine Rose
#6 Post by Eadwine Rose »
Since user has moved on I am closing this topic.
Locked
Return to “Installation”
