Come fare per vedere un DVD
Domenico
#1 Post by Domenico »
Buongiorno,
ho inserito un DVD nel mio PC desktop , ma non riesco a vederlo.
Per cortesia, mi dite cosa devo installare e/o fare?
Grazie.
Allego le info complete:
  Kernel: 6.10.12-1-liquorix-amd64 [6.10-16~mx23ahs] arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 parameters: audit=0
    intel_pstate=disable BOOT_IMAGE=/boot/vmlinuz-6.10.12-1-liquorix-amd64 root=UUID=<filter> ro
    quiet splash
    dm: LightDM v: 1.26.0 Distro: MX-23.4_ahs_x64 Libretto January 21  2024 base: Debian GNU/Linux
    12 (bookworm)
  Type: Desktop Mobo: ASUSTeK model: P8H61-M PRO v: Rev x.0x serial: <superuser required>
    UEFI: American Megatrends v: 4802 date: 09/18/2013
  Info: model: Intel Core i3-2130 bits: 64 type: MT MCP arch: Sandy Bridge gen: core 2 level: v2
    built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
    desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2327 high: 2973 min/max: 1600/3400 scaling: driver: acpi-cpufreq
    governor: ondemand cores: 1: 2587 2: 2973 3: 1800 4: 1951 bogomips: 28015
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: gather_data_sampling status: Not affected
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: l1tf mitigation: PTE Inversion
  Type: mmio_stale_data status: Unknown: No mitigations
  Type: reg_file_data_sampling status: Not affected
  Type: spec_rstack_overflow status: Not affected
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: conditional; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: AMD Turks PRO [Radeon HD 6570/7570/8550 / R5 230] vendor: ASUSTeK driver: radeon
    v: kernel alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
    built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: DVI-D-1
    empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 1002:6759 class-ID: 0300 temp: 40.0 C
  Display: x11 server: X.Org v: 1.21.1.7 compositor: xfwm v: 4.18.0 driver: X: loaded: radeon
    unloaded: fbdev,modesetting,vesa dri: r600 gpu: radeon display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: DVI-D-1 mapped: DVI-0 model: HP 2311x serial: <filter> built: 2011 res: 1920x1080
    hz: 60 dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3") diag: 585mm (23") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.5 Mesa 23.1.2-1~mx23ahs renderer: AMD TURKS (DRM 2.50.0 /
    6.10.12-1-liquorix-amd64 LLVM 15.0.6) direct-render: Yes
  Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK 6
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
  Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series] vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 1002:aa90 class-ID: 0403
  API: ALSA v: k6.10.12-1-liquorix-amd64 status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8P67 and other
    motherboards driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek 802.11ac NIC type: USB driver: rtw_8821cu bus-ID: 2-1.5:4 chip-ID: 0bda:c811
    class-ID: 0000 serial: <filter>
  Local Storage: total: 223.57 GiB used: 43.94 GiB (19.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB block-size:
    physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 041 scheme: GPT
  ID-1: / raw-size: 223.32 GiB size: 218.75 GiB (97.96%) used: 43.94 GiB (20.1%) fs: ext4
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 274 KiB (0.1%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: file size: 3 GiB used: 0 KiB (0.0%) priority: -2 file: /swap/swap
  System Temperatures: cpu: 34.0 C mobo: N/A gpu: radeon temp: 40.0 C
  Packages: pm: dpkg pkgs: 2164 libs: 1058 tools: apt,apt-get,aptitude,nala,synaptic pm: rpm
    pkgs: 0
    1: deb [arch=amd64] https://dl.google.com/linux/chrome/deb/ stable main
    1: deb http://it.mxrepo.com/mx/repo/ bookworm main non-free
    2: deb http://it.mxrepo.com/mx/repo/ bookworm ahs
  Processes: 293 Uptime: 10m wakeups: 1 Memory: 7.73 GiB used: 1.14 GiB (14.7%) Init: SysVinit
  v: 3.06 runlevel: 5 default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 12
Eadwine Rose
Re: Come fare per vedere un DVD
#2 Post by Eadwine Rose »
Spostato nel sottoforum delle lingue. La lingua del forum è l'inglese, per favore scrivete in inglese, a meno che non siate in questo sottoforum, grazie.
Si può provare: avviare MX Tools ed eseguire il programma di installazione dei codec.
MX-23.6_x64 July 31 2023 * 6.1.0-38amd64 ext4 Xfce 4.20.0 * 8-core AMD Ryzen 7 2700
j2mcgreg
#3 Post by j2mcgreg »
Potrebbe anche essere necessario cercare nel tuo mercato locale uno di questi:
www.amazon.ca/Arsvita-Player-Dics-Clean ... cLzCF3Vtf8
Reason: Italian forum
ryks
#4 Post by ryks »
VLC Player-right click on the dir[movie directory] and choose play with vlc ...
Eadwine Rose
#5 Post by Eadwine Rose »
@ryks Sei nel sottoforum italiano. Per favore, traduci il tuo post in italiano.
ryks
#6 Post by ryks »
VLC Player: fai clic con il pulsante destro del mouse su dir[directory dei film] e scegli Riproduci con vlc ...
Superiore
vitforlinux
#7 Post by vitforlinux »
Forse vuoi che Thunar apra direttamente i DVD in vlc quando li inserisci? Avevo fatto una guida tempo fa: https://vitforlinux.wordpress.com/2020/ ... jaro-xfce/
Excuse my spaghetti english, i m italian.
Return to “Forum Italiano”
