If you like Veromix (soundfaders automatic on command for each open sound-source): Veromix.
Veromix will mostly not install well, see the web with much complaints. Dependency-problem.
It is a gtk3 or gtk+ app now, so I did a gtk3 install (it is not in MX 17 I found).
Next install for instance Veromix 0.18.3-1.
If deb. with Gdebi (inclusive some supportive dependencies wich will be installed too).
Works fine and I'm very happy (again, I used it in other Linux distro's) with my soundcontrolpanel for each app.
