warpinator? [Solved]
entropyfoe
#1 Post by entropyfoe »
The only application missing from my MX23 install is warpinator.
It is one of those classic Linux programs, does one thing, and does it well.
I used it constantly on MX21, and now miss it, as it seems absent from the bookworm repos.
Can this useful search tool be packaged for MX23?
MX 23.6 on Asus PRIME B650
AMD Ryzen 9700X (16 threads @ 3.8 GHz)
64 Gig DDR4 6400 (Crucial)
Nvidia GeForce GT 710
Samsung 970 NVMe nvme0n1 P1-3=MX-23.5, P4=testing
Samsung 980 NVMe =2TB Data, plus 4TB WD =backups
on-board ethernet & sound
BV206
Re: warpinator?
#2 Post by BV206 »
Warpinator is in the Flatpak repo. It looks like right now that is the only way to install it.
entropyfoe
Re: warpinator?
#3 Post by entropyfoe »
OK, thanks for the lead.
I'll check into that.
I never used the flatpacks before, due to the updating limitations, but I will try and install it.
entropyfoe
Re: warpinator?
#4 Post by entropyfoe »
OK, I used the MXPI , in the flatpacks tab, to get warpinator installed.
It worked, though couldn't see the other computers on the home network.
This was not the default behavior in MX21 and 19.
I had to turn the firewall off, then it works normally.
I am behind a NAT router on a home network.
I can look into keeping it on while making a rule for warpinator, I think ports like 42000 need to be open.
Re: warpinator?
#5 Post by Stevo »
Warpinator isn't in any Debian repos; we've been porting it over from Mint for MX, but missed doing it so far for MX 23. I'll see if I can get to it later tonight.
MXPI = MX Package Installer
QSI = Quick System Info from menu
The MX Test repository is mostly backports; not the same as Debian testing
BV206
Re: warpinator?
#6 Post by BV206 »
There are instructions for firewall settings on their github page.
https://github.com/linuxmint/warpinator
entropyfoe
Re: warpinator?
#7 Post by entropyfoe »
BV206,
Wow, that is the exact information. Thanks.
I will check that out once I see if Stevo can get it in the regular package.
The flatpack and the regular versions seem to have different ways of dealing with the firewall.
junoluna
Re: warpinator?
#8 Post by junoluna »
thanks for bringing this up
i find it an extremely useful app
i also installed from flatpak and cannot see the other devices on the network
Re: warpinator?
#9 Post by Stevo »
Here's the latest 1.6.4 for MX 23 if you want to let me know how it works: https://drive.google.com/file/d/1fetVzW ... sp=sharing
It will also be in the test repo.
entropyfoe
Re: warpinator?
#10 Post by entropyfoe »
Thanks Stevo, Do I have to un-install the flat[pack first with the MXPI?
I don't want to screw this up, as I use warpinator a lot.
Return to “Package Requests - MX-23”
