Mirror synchronization problems
mxlinux-cica
#1 Post by mxlinux-cica »
Hello,
Since January 20th we are having synchronization problems with 'iso.mxrepo.com' and 'rsync-mxlinux.org' mirror.
The error is the following:
rsync: connection unexpectedly closed (5357 bytes received so far) [receiver].
rsync error: error in rsync protocol data stream (code 12) at io.c(226) [receiver=3.1.2] [receiver=3.1.2].
Is there a problem with the synchronization servers?
Greetings.
Eadwine Rose
Re: Mirror synchronization problems
#2 Post by Eadwine Rose »
You can use the MX Repo Manager to change to a different one.
mxlinux-cica
#3 Post by mxlinux-cica »
Thank you very much for your response.
Our server hasn't got a graphical environment. So we can't use the tool.
Normally we haven't problem with synchronization. But now we get the error following for the 'rsync-mxlinux.org::MX-Linux':
rsync error: error in rsync protocol data stream (code 12) at io.c(226) [receiver=3.1.2] [receiver=3.1.2] [rsync error: error in rsync protocol data stream (code 12) at io.c(226)
rsync: [generator] write error: Broken pipe (32)
rsync error: error in socket IO (code 10) at io.c(820) [generator=3.1.2] rsync: [generator=3.1.2] rsync: [generator] write error: Broken pipe (32)
Is it possible that there is a problem on the target server?
Greetings.
Eadwine Rose
#4 Post by Eadwine Rose »
Please post your Quick System Info, thank you.
#5 Post by dolphin_oracle »
Eadwine Rose wrote: Fri Feb 03, 2023 8:23 am Please post your Quick System Info, thank you.
I think they are mirroring our servers @Eadwine Rose , this isn't a usual support requeset. QSI doesn't mean anything in this case.
@mxlinux-cica the rsync-mxlinux.org server is up, and there are many many mirrors syncing to it. which mirror do you represent?
Last edited by dolphin_oracle on Fri Feb 03, 2023 8:35 am, edited 1 time in total.
Eadwine Rose
#6 Post by Eadwine Rose »
Owh...
*looks up, sees birds fly over the head going tweet tweet*
mxlinux-cica
#7 Post by mxlinux-cica »
Attached the synchronization command:
$ rsync -vaHz --password-file=/etc/rsyncd.secrets-mxisos --stats --exclude-from=/srv/conf/Mirror/packages/excludes-mxlinuxisos --delete-excluded --delete-after downstreamtestuser@rsync-mxlinux.org::MX-Linux/ /srv/ftp/mirrors/Linux/MX-ISOs
receiving file list ... done
Greetings.
#8 Post by dolphin_oracle »
@mxlinux-cica thanks for the command.
which mirror are you?
mxlinux-cica
#9 Post by mxlinux-cica »
I'm not sure of the information you are asking for, it refers to: https://launchpad.net/ubuntu/+mirror/ub ... es-archive ?
Greetings.
#10 Post by dolphin_oracle »
I'm asking for the address of the mirror you are trying to populate.
Return to “MX Repositories”
