And if I looked at the current UUID, what else to do?
Sysvinit works, Systemd doesn't [Solved]
Re: Sysvinit works, Systemd doesn't
As root, make a backup of the file, /etc/fstab, of the distro controlling the boot.
Compare the UUID of swap partition to the result of blkid from fstab of distro controlling the boot.
If different, then change the UUID in /etc/fstab and reboot.
Note:
blkid gives all the info though not formatted very well.
sudo lsblk -o NAME,FSTYPE,SIZE,LABEL,MOUNTPOINT,UUID
is more legible format
and
lsblk -f
is easier & legible! [Thanks @ fehlix]
Note:
and
lsblk -f
__kernal 5.10.0-26-amd64 x86_64; Xfce-4.18.0; 8 GB RAM
__Intel Core i5-3380M, Graphics, Audio, Video; & SSDs.
HP Ryzen 5 17-cp3xxx with MX23.4 AHS & Liquorix 6.10-12~mx23ahs amd64
I made changes to the swap, including, of course, disabling it, the situation remained the same. The problem may be caused by the EFI partition, but other distributions with systemd installed on the machine are working fine.Richard wrote: Wed Dec 01, 2021 9:53 am As root, make a backup of the file, /etc/fstab, of the distro controlling the boot.
Note:
Our efi partition is mounted in fstab as well.
Strticlty speaking it’s not required to mount it at all. So you can comment the line out in fstab and see if that helps
@DO, yes I thought about that.
There is more automation that probably obviates the need to tweak fstab.
I think you are correct, the issue is deeper than fstab.
I have only ever used systemd for a while when Manjaro went there.
My main reason for hopping away from Manjaro.
Bingo!dolphin_oracle wrote: Thu Dec 02, 2021 7:04 am Our efi partition is mounted in fstab as well.
● mx
State: running
Jobs: 0 queued
Failed: 0 units
Since: Thu 2021-12-02 16:24:31 CET; 5min ago
CGroup: /
├─user.slice
│ └─user-1000.slice
│ ├─user@1000.service …
│ │ ├─app.slice
│ │ │ ├─pulseaudio.service
│ │ │ │ └─1681 /usr/bin/pulseaudio --daemonize=no --log-target=journal
│ │ │ └─gpg-agent.service
│ │ │ └─1848 /usr/bin/gpg-agent --supervised
│ │ └─init.scope
│ │ ├─1661 /lib/systemd/systemd --user
│ │ └─1662 (sd-pam)
│ └─session-2.scope
│ ├─1411 lightdm --session-child 12 19
│ ├─1684 /usr/bin/gnome-keyring-daemon --daemonize --login
│ ├─1687 xfce4-session
│ ├─1732 dbus-launch --autolaunch=fd3922b3b21c7a69d665653c5dd718cc --binary-syntax --close-stderr
│ ├─1733 /usr/bin/dbus-daemon --syslog-only --fork --print-pid 5 --print-address 7 --session
│ ├─1736 /usr/lib/x86_64-linux-gnu/xfce4/xfconf/xfconfd
│ ├─1748 /usr/bin/dbus-launch --exit-with-session --sh-syntax
│ ├─1749 /usr/bin/dbus-daemon --syslog --fork --print-pid 5 --print-address 7 --session
│ ├─1796 /usr/bin/ssh-agent x-session-manager
│ ├─1819 /usr/libexec/gvfsd
│ ├─1824 /usr/libexec/gvfsd-fuse /run/user/1000/gvfs -f
│ ├─1832 /usr/lib/x86_64-linux-gnu/xfce4/xfconf/xfconfd
│ ├─1838 /usr/bin/xfce4-screensaver --no-daemon
│ ├─1850 xfwm4
│ ├─1857 xfsettingsd
│ ├─1890 xfce4-panel
│ ├─1894 Thunar --daemon
│ ├─1899 xfdesktop
│ ├─1900 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libwhiskermenu.so 20 29360139 whiskermenu Whisker Menü menü megjelenítése a telepített alkalmazások könnyű eléréséhez
│ ├─1905 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libsystray.so 6 29360141 systray Status Tray Plugin Provides status notifier items (application indicators) and legacy systray items
│ ├─1906 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libactions.so 9 29360142 actions Műveletgombok Kijelentkezés, zárolás vagy más rendszerműveletek
│ ├─1907 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libweather.so 2 29360143 weather Időjárási adatok frissítése A jelenlegi időjárási helyzet megjelenítése
│ ├─1908 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libbattery.so 13 29360144 battery Akkumulátorfigyelő Az akkumulátor állapotának megjelenítése és figyelése
│ ├─1909 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libpulseaudio-plugin.so 1 29360145 pulseaudio PulseAudio bővítmény A PulseAudio hangrendszer hangerejének beállítása
│ ├─1910 /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-2.0 /usr/lib/x86_64-linux-gnu/xfce4/panel/plugins/libdatetime.so 14 29360146 datetime Dátum/idő Dátum és idő bővítmény egyszerű naptárral
│ ├─1943 plank
│ ├─1950 /usr/bin/python3 /usr/bin/blueman-applet
│ ├─1972 fbxkb
│ ├─1973 mx-usb-unmounter
│ ├─1975 /usr/lib/x86_64-linux-gnu/libexec/kdeconnectd
│ ├─1983 /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
│ ├─1999 nm-applet
│ ├─2008 /usr/lib/x86_64-linux-gnu/xfce4/notifyd/xfce4-notifyd
│ ├─2011 xfce4-power-manager
│ ├─2020 xiccd
│ ├─2026 diodon
│ ├─2033 /usr/bin/python3 /usr/share/system-config-printer/applet.py
│ ├─2044 /usr/libexec/dconf-service
│ ├─2066 /bin/bash /usr/libexec/bamf/bamfdaemon-dbus-runner
│ ├─2070 /usr/libexec/bamf/bamfdaemon
│ ├─2076 /bin/sh -c /usr/lib/zeitgeist/zeitgeist-maybe-vacuum; /usr/bin/zeitgeist-daemon
│ ├─2083 /usr/bin/zeitgeist-daemon
│ ├─2095 /usr/lib/zeitgeist/zeitgeist-fts
│ ├─2110 /usr/bin/python3 /usr/bin/blueman-tray
│ ├─2120 /usr/libexec/bluetooth/obexd
│ ├─2147 /usr/libexec/gvfs-udisks2-volume-monitor
│ ├─2153 /usr/libexec/gvfs-gphoto2-volume-monitor
│ ├─2158 /usr/libexec/gvfs-mtp-volume-monitor
│ ├─2163 /usr/libexec/gvfs-goa-volume-monitor
│ ├─2168 /usr/libexec/gvfs-afc-volume-monitor
│ ├─2179 /usr/libexec/gvfsd-trash --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
│ ├─2185 /usr/libexec/gvfsd-metadata
│ ├─2224 /usr/bin/python3 /usr/lib/apt-notifier/modules/apt-notifier.py
│ ├─2292 conky -c /home/zoli62/.conky/MX-APInfo/AP-info-debianUpdates-coloursMod
│ ├─2441 /bin/bash /usr/bin/mx-pkexec doublecmd
│ ├─2442 doublecmd
│ ├─2506 dbus-launch --autolaunch fd3922b3b21c7a69d665653c5dd718cc --binary-syntax --close-stderr
│ ├─2507 /usr/bin/dbus-daemon --syslog-only --fork --print-pid 5 --print-address 7 --session
│ ├─2554 xfce4-terminal
│ ├─2559 bash
│ ├─2584 su
│ ├─2605 bash
│ └─2614 systemctl status
├─init.scope
│ └─1 /lib/systemd/systemd
└─system.slice
├─haveged.service
│ └─397 @usr/sbin/haveged --Foreground --verbose=1
├─acpi-fakekey.service
│ └─800 /usr/sbin/acpi_fakekeyd -f
├─systemd-udevd.service
│ └─353 /lib/systemd/systemd-udevd
├─cron.service
│ └─1012 /usr/sbin/cron -f
├─nfs-mountd.service
│ └─927 /usr/sbin/rpc.mountd --manage-gids
├─polkit.service
│ └─811 /usr/libexec/polkitd --no-debug
├─bluetooth.service
│ └─1231 /usr/libexec/bluetooth/bluetoothd
├─accounts-daemon.service
│ └─799 /usr/libexec/accounts-daemon
├─wpa_supplicant.service
│ └─817 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
├─lightdm.service
│ ├─1039 /usr/sbin/lightdm
│ └─1098 /usr/lib/xorg/Xorg -dpi $DPI :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
├─ModemManager.service
│ └─903 /usr/sbin/ModemManager
├─nmbd.service
│ └─1507 /usr/sbin/nmbd --foreground --no-process-group
├─systemd-journald.service
│ └─331 /lib/systemd/systemd-journald
├─unattended-upgrades.service
│ └─901 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
├─colord.service
│ └─1025 /usr/libexec/colord
├─NetworkManager.service
│ └─807 /usr/sbin/NetworkManager --no-daemon
├─nfs-blkmap.service
│ └─345 /usr/sbin/blkmapd
├─rsyslog.service
│ └─812 /usr/sbin/rsyslogd -n -iNONE
├─rpcbind.service
│ └─398 /sbin/rpcbind -f -w
├─nfs-idmapd.service
│ └─357 /usr/sbin/rpc.idmapd
├─cups-browsed.service
│ └─1121 /usr/sbin/cups-browsed
├─smartmontools.service
│ └─814 /usr/sbin/smartd -n
├─cups.service
│ └─895 /usr/sbin/cupsd -l
├─upower.service
│ └─1861 /usr/libexec/upowerd
├─udisks2.service
│ └─816 /usr/libexec/udisks2/udisksd
├─acpid.service
│ └─801 /usr/sbin/acpid
├─ntp.service
│ └─954 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 105:112
├─smbd.service
│ ├─1518 /usr/sbin/smbd --foreground --no-process-group
│ ├─1520 /usr/sbin/smbd --foreground --no-process-group
│ ├─1521 /usr/sbin/smbd --foreground --no-process-group
│ └─1524 /usr/sbin/smbd --foreground --no-process-group
├─dbus.service
│ └─806 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
├─system-getty.slice
│ └─getty@tty1.service
│ └─1512 /sbin/agetty -o -p -- \u --noclear tty1 linux
├─avahi-daemon.service
│ ├─804 avahi-daemon: running [mx.local]
│ └─818 avahi-daemon: chroot helper
└─systemd-logind.service
└─815 /lib/systemd/systemd-logind
Haven't tried EndeavourOS? Although it also works with systemd.Richard wrote: Thu Dec 02, 2021 8:37 am @DO, yes I thought about that.
Final solution.Richard wrote: Sat Nov 27, 2021 3:23 pm Many years ago, systemd would go to emegency shell
if the swap was formatted during installation of another distro.
UUID of swap changed.
Maybe it still does?
You're right, it wasn't just the swap partition that was the problem, but the EFI partition, whose UUID changed for some mysterious reason. I think this may have been when I installed Kubuntu on this laptop after installing the other distributions. As soon as I changed the UUID of the EFI partition in the fstab file to the one in the output of the lsblk -o command, the system started immediately, smoothly with no problems. Thanks for the tip, a lesson is that if you have multiple operating systems installed on a drive in a row, you should pay attention to that as well.
I'm thinking the EFI partition is being formatted by whatever installer kubuntu is using. formatting the partition changes the UUID.zoli62 wrote: Wed Dec 08, 2021 11:21 pmFinal solution.Richard wrote: Sat Nov 27, 2021 3:23 pm Many years ago, systemd would go to emegency shell
Thanks for everything. This may have been the cause of the problem. One often does not pay attention to such a banal thing. For example, for multiple boot, installing the most recent distribution may affect the previous ones.dolphin_oracle wrote: Thu Dec 09, 2021 10:08 amI'm thinking the EFI partition is being formatted by whatever installer kubuntu is using. formatting the partition changes the UUID.zoli62 wrote: Wed Dec 08, 2021 11:21 pmFinal solution.Richard wrote: Sat Nov 27, 2021 3:23 pm Many years ago, systemd would go to emegency shell
