MX-21 beta 2 feedback thread (xfce)
Stuart_M
Re: MX-21 beta 2 feedback thread (xfce)
#101 Post by Stuart_M »
marybaca wrote: Thu Sep 09, 2021 1:58 pm Changing application Menu icon takes 20+ second to load...
marybaca wrote: Thu Sep 09, 2021 2:35 pm
asqwerth wrote: Thu Sep 09, 2021 2:05 pm @marybaca
Always been the case for me in any xfce distro, as the program goes through and collates all the available icons into the various categories.
Thank you for pointing it out. Out of curiosity I just tried the same thing on Mint XFCE 20.1, Debian 10.9 XFCE, Xubuntu 20.04 and it is relatively instantaneous.
Though mx21 beta2 is using Xfce 4.16, which is newer than the others. I wonder if it is just an issue with Xfce 4.16.
@asqwerth thanks for the explanation!
I wanted to see if there was any difference in times between MX-21, MX-19 and MX-18 when changing a Desktop icon using the "Edit Launcher" or "Properties" window.
All three releases are using the same Ryzen 5 (AF) 1600 CPU (6C/12T, base clock of 3.2 GHz, boost 3.6GHz). I didn't care about the icon loading delay as much as what the differences are between the three releases (the delay has a lot to do with the computer speed too).
All of my times are based on the same CPU and motherboard (with 16GB RAM). Each MX Linux release is on its own SSD (Crucial MX-500). MX-18 and 19 are using Full Disk Encryption, MX-21 is not (so that alone should give MX-21 a tiny advantage).
What I found was that it's getting worse as the releases progress. Okay okay, a tiny bit worse, but it's certainly not getting better.
I tested each release with a stopwatch, beginning from when I clicked on the icon in "Edit Launcher" and ending when the window to select icons appeared. I checked 12 different icons on each release and averaged the time. Every test was easily within 200ms of the other 11. These are the results:
  • MX-21 = 11.2 seconds
  • MX-19 = 9.3 seconds
  • MX-18 = 6.2 seconds
On each release I used the ManyRoads/cpufile Conky that displays the CPU activity percentage for each of the 12 threads. It is interesting to note that after I clicked the icon to change, CPU activity in MX-21 was usually 30-60% with an occasional jump to ~75% toward the end (depended on which package I was testing). In MX-19 CPU activity quickly jumps to 75-90% and for the most part stays there, never going to more than 95%. CPU activity In MX-18 quickly jumps up to 90-95% and then quickly goes to 100% and stays there until the icon selection window appears. All tests showed that only one thread was used during the change.
And yes, I have a lot of free time (retired).
dreamer
#102 Post by dreamer »
@Stuart_M
There are a few variables:
How many icon packs installed or maybe it only searches current icon pack with or without "Inherits".
Whether the icon packs have a cache file or not (otherwise warnings will show in Settings Manager > Appearance > Icons tab
I guess it's an Xfce utility that does this, maybe exo something. It can be useful, but also annoying. I think MATE only opens an Open Dialog. It's instant, but you have to browse the file system yourself.
There are a few niggles in Xfce like Preferred Applications. MATE automatically adds from installed applications. Xfce requires separate desktop files for this that you have to add manually, but in MX-21 it is actually taken care of by a package full of "Preferred Applications files" for Xfce 4.16.
We all dream of the perfect system, don't we? It's frustrating, but MX-21 looks good. I feel it's the last one with Xfce for me so personally I feel it's nice to see Xfce go out with a bang. Other people may of course enjoy upcoming Xfce 4.18 etc.
:turtle:
Note to self and others: SysVinit is a good option. However if you run into problems try with systemd first. This applies to AppImages, Flatpaks, GitHub packages and even some Debian packages.
Richard
#103 Post by Richard »
Eadwine Rose wrote: Wed Sep 08, 2021 10:08 am Where did setting the key to grab and move windows go to? You know.. when you need to move something and you cannot grab the top bar, you press and hold that key and then left mouse button click anywhere in it and drag the whole thing. That setting. For the life of me I cannot seem to find it. :)
Press & Hold Alt key and hold Left mouse button.
Move the mouse to position.
Really handy,
__kernal 5.10.0-26-amd64 x86_64; Xfce-4.18.0; 8 GB RAM
__Intel Core i5-3380M, Graphics, Audio, Video; & SSDs.
HP Ryzen 5 17-cp3xxx with MX23.4 AHS & Liquorix 6.10-12~mx23ahs amd64
hughbert
#104 Post by hughbert »
I am getting an error after attempting to install signal-desktop per the instructions on the signal website (https://www.signal.org/download/#)
After executing step 2.
 echo 'deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main' |\
  sudo tee -a /etc/apt/sources.list.d/signal-xenial.list
The system just hangs. So I closed the window after about 20 minutes.
No when I attempt to do any system update/upgrade I get this back;
E: Conflicting values set for option Signed-By regarding source https://updates.signal.org/desktop/apt/ xenial: /usr/share/keyrings/signal-desktop-keyring.gpg !=
E: The list of sources could not be read.
or:
How can I fix this?
Thank you.
System:    Host: <filter> Kernel: 5.10.0-8-amd64 x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10.0-8-amd64
           root=UUID=<filter> ro quiet splash
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
           Distro: MX-21_beta1_x64 Wildflower July 27  2021 base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: Laptop System: Dell product: Inspiron 5759 v: N/A serial: <filter> Chassis:
           type: 10 serial: <filter>
           Mobo: Dell model: 05NVNV v: A00 serial: <filter> UEFI: Dell v: 1.7.0 date: 05/10/2019
Battery:   ID-1: BAT0 charge: 14.9 Wh condition: 14.9/41.4 Wh (36%) volts: 16.8/14.8
           model: SMP DELL VN3N047 type: Li-ion serial: <filter> status: Full
CPU:       Topology: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
           family: 6 model-id: 4E (78) stepping: 3 microcode: EA L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20799
           Speed: 800 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spec_store_bypass
           mitigation: Speculative Store Bypass disabled via prctl and seccomp
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
           STIBP: conditional, RSB filling
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:1916
           Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520
           Mobile]
           vendor: Dell driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6660
           Display: x11 server: X.Org 1.20.11 driver: ati,modesetting,radeon
           unloaded: fbdev,vesa resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.3.5
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
           v: kernel bus ID: 00:1f.3 chip ID: 8086:9d70
           Sound Server: ALSA v: k5.10.0-8-amd64
Network:   Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
           chip ID: 8086:08b3
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169
           v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8136
           IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives:    Local Storage: total: 223.57 GiB used: 9.62 GiB (4.3%)
           ID-1: /dev/sda model: SSD 240GB size: 223.57 GiB block size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 6A temp: 35 C scheme: GPT
Partition: ID-1: / raw size: 107.42 GiB size: 105.18 GiB (97.91%) used: 9.60 GiB (9.1%) fs: ext4
           dev: /dev/sda5
Sensors:   System Temperatures: cpu: 51.0 C mobo: 40.0 C sodimm: 38.0 C gpu: radeon temp: 29 C
           Fan Speeds (RPM): cpu: 0
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/brave-browser-release.list
           1: deb [arch=amd64] https://brave-browser-apt-release.s3.brave.com/ bullseye main
           1: deb http://mxrepo.com/mx/repo/ bullseye main non-free
           Active apt repos in: /etc/apt/sources.list.d/signal-xenial-added-by-mxpi.list
           1: deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main
           2: deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main
           3: deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main
           Active apt repos in: /etc/apt/sources.list.d/signal-xenial.list
           1: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
           3: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
           4: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
           5: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
           6: deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main
           Active apt repos in: /etc/apt/sources.list.d/windscribe-repo.list
           1: deb https://repo.windscribe.com/debian buster main
Info:      Processes: 236 Uptime: 12m Memory: 7.54 GiB used: 1.47 GiB (19.5%) Init: SysVinit
           v: 2.96 runlevel: 5 default: 5 Compilers: gcc: 10.2.1 alt: 10 Shell: quick-system-in
           running in: quick-system-in inxi: 3.0.36
#105 Post by dolphin_oracle »
hughbert wrote: Thu Sep 09, 2021 8:22 pm I am getting an error after attempting to install signal-desktop per the instructions on the signal website (https://www.signal.org/download/#)
or:
How can I fix this?-
Thank you.
           Mobile]
           chip ID: 8086:08b3
           dev: /dev/sda5
I think you messed up your command. you also have the signal repo defined 6 times in the file, and I think one of them is wrong.
I would delete the /etc/apt/sources.list.d/signal-xenial.list file, run an "apt-get update" after that, and then use mx-packageisntaller->popular apps to install signal-desktop. it will set up the repo and gpg keys for you.
hughbert
#106 Post by hughbert »
I actually just copy/pasted the command. Anyway, now it's working, thank you.
BasicSloth
#107 Post by BasicSloth »
@SwampRabbit
Yes I'm using AHS
Thank you! I will do some further tests in the evening and will read about the meaning of "segfaults" as I found some in the logs.
Sep  9 20:31:36 mx1 kernel: [    9.574556] lp: driver loaded but no devices found
Sep  9 20:31:36 mx1 kernel: [    9.583763] ppdev: user-space parallel port driver
Sep  9 20:31:36 mx1 kernel: [  120.479976] mountnfs[3521]: segfault at 0 ip 00007f1941477ca4 sp 00007ffc8cd16a98 error 4 in libc-2.31.so[7f1941342000+14b000]
Sep  9 20:31:36 mx1 kernel: [  120.479979] Code: 3a 63 c9 3a 83 f9 10 0f 84 f9 00 00 00 89 fe 48 89 f8 83 e6 0f 74 4b 48 83 e0 f0 48 8d 0d e4 a7 02 00 48 63 d6 f3 0f 6f 14 11 <66> 0f 6f 00 66 0f 38 00 c2 66 0f 3a 63 c8 02 72 15 ba 10 00 00 00
Sep  9 20:31:38 mx1 kernel: [  124.730684] Bluetooth: BNEP socket layer initialized
Sep  9 20:31:41 mx1 kernel: [  127.735616] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
Sep  9 20:32:26 mx1 kernel: [  172.515347] xfce4-session[4645]: segfault at 2c ip 000055c09132d770 sp 00007ffe36514ab8 error 4 in xfce4-session[55c091318000+1c000]
Sep  9 20:32:26 mx1 kernel: [  172.515357] Code: b6 fe ff 0f 1f 80 00 00 00 00 4c 89 e7 e8 f8 ed ff ff 85 c0 75 b5 48 83 c4 08 4c 89 e7 5d 41 5c e9 e5 f2 ff ff 0f 1f 44 00 00 <8b> 47 2c c3 66 66 2e 0f 1f 84 00 00 00 00 00 90 8b 47 28 c3 66 66
Sep  9 20:32:41 mx1 kernel: [  187.274841] lightdm[5336]: segfault at 1 ip 00007f3db223dad1 sp 00007ffda4f18168 error 4 in libc-2.31.so[7f3db2103000+14b000]
Sep  9 20:32:41 mx1 kernel: [  187.274848] Code: 84 00 00 00 00 00 0f 1f 00 31 c0 c5 f8 77 c3 66 2e 0f 1f 84 00 00 00 00 00 89 f9 48 89 fa c5 f9 ef c0 83 e1 3f 83 f9 20 77 1f <c5> fd 74 0f c5 fd d7 c1 85 c0 0f 85 df 00 00 00 48 83 c7 20 83 e1
Sep  9 20:32:46 mx1 kernel: [  192.224288] panel-7-power-m[5598]: segfault at 400 ip 00007f3b55e1fad1 sp 00007ffccf54d5b8 error 4 in libc-2.31.so[7f3b55ce5000+14b000]
Sep  9 20:32:46 mx1 kernel: [  192.224294] Code: 84 00 00 00 00 00 0f 1f 00 31 c0 c5 f8 77 c3 66 2e 0f 1f 84 00 00 00 00 00 89 f9 48 89 fa c5 f9 ef c0 83 e1 3f 83 f9 20 77 1f <c5> fd 74 0f c5 fd d7 c1 85 c0 0f 85 df 00 00 00 48 83 c7 20 83 e1
Sep  9 20:33:00 mx1 kernel: [  206.692683] xfce4-session[5380]: segfault at 2c ip 00005615c00d7770 sp 00007ffedbf77138 error 4 in xfce4-session[5615c00c2000+1c000]
Sep  9 20:33:00 mx1 kernel: [  206.692691] Code: b6 fe ff 0f 1f 80 00 00 00 00 4c 89 e7 e8 f8 ed ff ff 85 c0 75 b5 48 83 c4 08 4c 89 e7 5d 41 5c e9 e5 f2 ff ff 0f 1f 44 00 00 <8b> 47 2c c3 66 66 2e 0f 1f 84 00 00 00 00 00 90 8b 47 28 c3 66 66
Vipul88
#108 Post by Vipul88 »
how do i disable/edit/change/replace the keybind of SUPER to open whisker menu? cant find the exact keybind for whiskermenu in keyboard and window manager keyboard tab.
Eadwine Rose
#109 Post by Eadwine Rose »
In keyboard, application shortcuts, Super L is set to popup whiskermenu: xfce4-popup-whiskermenu
Click the entry, click edit, you can change the key there, or remove it altogether by removing that line (click remove).
(note that I AM typing this from 19.4 but I don't think this has changed)
Vipul88
#110 Post by Vipul88 »
Eadwine Rose wrote: Fri Sep 10, 2021 2:39 am In keyboard, application shortcuts, Super L is set to popup whiskermenu: xfce4-popup-whiskermenu
I just checked session and startup application and find out that
xfce-superkey
was being autostarted.
P.s. I know you have that super+L entry in your keyboard shortcuts dialogue box. The thing is I don't have any of such entry in beta 2. That's the reason i asked in here. However I found the reason for that as mentioned above. Thanks for your response in either case.
Locked
