MX-19 Beta 2.1 Feedback
Re: MX-19 Beta 2.1 Feedback
#251 Post by dolphin_oracle »
richb wrote: Wed Sep 11, 2019 9:21 pm 18.3
MX-19beta-2.1
I see the problem the UUID for data partition in 18.3 is identical to the UUID for the 512MB vfat partiton. Not sure if changing the partition UUID in 19 beta to the one in 18.3 would resolve the problem.
And more to the point for feedback why it happened.
Other than having to mount the partition at each boot the Data partition acts normally in when mounted.
not according to your 2 fstab snippets. UUIDs shouldn't change.
UUID for /dev/sdc3 on from your 18.3 fstab
#Entry for /dev/sdc3 :
UUID=184c55f9-094f-40b6-85f2-07a47f4e8fb2	/media/data_SSD	ext4	defaults	0	0
which matches the disk manager image in your 18.3 screenshot.
and the one show in your 19 fstab
#Entry for /dev/sdc1 :
UUID=7B34-0958	/media/sdc1	vfat	defaults,utf8,umask=0	0	2
which matches the checked box in your disk manager image for 19
so can you do this.
1. on 19, check the box marked for sdc3 but do not close disk manager.
2. in a terminal,
cat /etc/fstab
and lets see if it makes the change.
#252 Post by dolphin_oracle »
chrispop99 wrote: Wed Sep 11, 2019 9:31 am
dolphin_oracle wrote: Wed Sep 11, 2019 8:30 am
chrispop99 wrote: Wed Sep 11, 2019 8:19 am
I tried first without checking the box to install unsupported driver (1stddm.log) and then secondly checking the box to install the unsupported driver (2ndddm.log).
thank you, I think I see the issue.
could you try this:
apt-get install --install-recommends --reinstall bumblebee-nvidia nvidia-legacy-390xx-driver primus primus-libs-ia32:i386 nvidia-settings virtualgl virtualgl-libs:i386
It ran but didn't work. Terminal output attached.
chris,
can you provide the output of
nvidia-detect
please.
It looks like your card maxes out with the nvidia-legacy-390xx-driver, which is supposed to work with primus, but there is a conflict between primus and one of the driver libs. I haven't been able to resolve it.
tagging stevo on this one.
***edit***
I'm thinking the primus stuff is set so that it only works with nvidia-driver.
so can we skip that?
apt-get install --install-recommends --reinstall bumblebee-nvidia nvidia-legacy-390xx-driver nvidia-settings -s
seems to bring in a lot of stuff, but will optirun work?
JayM
#253 Post by JayM »
AK-47 wrote: Wed Sep 11, 2019 7:07 am On that note, MXPI doesn't like going to Debian Backports. When you click the Backports tab, it does some processing and then immediately without any message, flips back to the popular apps tab.
FYI I'm not seeing this behavior on my system with a persistent live USB:
System:    Host: mx1 Kernel: 4.19.0-6-686-pae i686 bits: 32 compiler: gcc v: 8.3.0
           Desktop: Xfce 4.14.1 tk: Gtk 3.24.5 info: xfce4-panel wm: xfwm4 dm: LightDM 1.26.0
           Distro: MX-19beta-2.1_386 patito feo September 8  2019
           base: Debian GNU/Linux 10 (buster)
Machine:   Type: Other-vm? System: AVERATEC product: N1130 v: N/A serial: <filter>
           Chassis: No Enclosure type: 1 serial: <filter>
           Mobo: AVERATEC model: N1130 serial: <filter> BIOS: Phoenix
           v: NAPA0001.86C.0056.D.0907311757 date: 07/31/09
Battery:   ID-1: BAT0 charge: 0.2 Wh condition: 0.2/2.1 Wh (10%) volts: 1.1/65.4
           model: AVERATEC N1130 type: Li-ion serial: N/A status: Full
CPU:       Topology: Single Core model: Intel Atom N270 bits: 32 type: MT arch: Bonnell
           family: 6 model-id: 1C (28) stepping: 2 microcode: 218 L2 cache: 512 KiB
           flags: nx pae sse sse2 sse3 ssse3 bogomips: 6384
           Speed: 1219 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 901 2: 1160
           Vulnerabilities: Type: l1tf status: Not affected
           Type: spec_store_bypass status: Not affected
           Type: spectre_v1 status: Not affected
           Type: spectre_v2 status: Not affected
Graphics:  Device-1: Intel Mobile 945GSE Express Integrated Graphics driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:27ae
           Display: x11 server: X.Org 1.20.4 driver: intel resolution: 1280x1024~60Hz
           OpenGL: renderer: Mesa DRI Intel 945GME x86/MMX/SSE2 v: 1.4 Mesa 18.3.6
Audio:     Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
           v: kernel bus ID: 00:1b.0 chip ID: 8086:27d8
           Sound Server: ALSA v: k4.19.0-6-686-pae
Network:   Device-1: Ralink RT3090 Wireless 802.11n 1T/1R PCIe driver: rt2800pci v: 2.3.0
           port: 18e0 bus ID: 02:00.0 chip ID: 1814:3090
           Device-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet driver: r8169
           v: kernel port: 2000 bus ID: 04:00.0 chip ID: 10ec:8136
Drives:    Local Storage: total: 126.24 GiB used: 6.45 GiB (5.1%)
           ID-1: /dev/sda vendor: Gigabyte model: GP-GSTFS31120GNTD size: 111.79 GiB block size:
           physical: 512 B logical: 512 B speed: <unknown> serial: <filter> rev: 61.3
           scheme: MBR
           ID-2: /dev/sdb type: USB vendor: Toshiba model: TransMemory size: 14.45 GiB
           block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw size: N/A size: 1.49 GiB used: 138.8 MiB (9.1%) fs: overlay
           source: ERR-102
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
           1: deb http://iso.mxrepo.com/antix/buster buster main
           1: deb http://deb.debian.org/debian buster-updates main contrib non-free
           1: deb http://deb.debian.org/debian buster main contrib non-free
           2: deb http://deb.debian.org/debian-security buster/updates main contrib non-free
           1: deb http://mxrepo.com/mx/repo/ buster main non-free
Info:      Processes: 185 Uptime: 16m Memory: 1.90 GiB used: 507.0 MiB (26.1%) Init: SysVinit
           v: 2.93 runlevel: 5 default: 5 Compilers: gcc: 8.3.0 alt: 8 Shell: bash v: 5.0.3
           running in: quick-system-in inxi: 3.0.33
Are you using different repo mirrors? Maybe the problem is with them.
(FYI I've temporarily disabled the netbook's monitor in Settings/Display because it's annoying having to use non-full-sized apps, in case anyone noticed the resolution within my QSI.)
#254 Post by dolphin_oracle »
JayM wrote: Wed Sep 11, 2019 10:11 pm
           scheme: MBR
           source: ERR-102
I'm not seeing this on my production system at home, but I can reproduce the situation at work.
However, I'm not sure the cause. the machine at work has a flakey internet connection, and is a very slow machine. I can monitor the /tmp folder for the mxpi temp folder to be created. On the occasions where mxpi fails (and it doesn't always), the temp folder never gets created.
JayM
#255 Post by JayM »
Maybe a timeout that's too short?
#256 Post by richb »
I do not see that on my installed system. Debian backports pops up in a couple seconds. Pretty fast computer. Is that the difference?
System:    Host: mx Kernel: 4.19.0-6-amd64 x86_64 bits: 64 Desktop: Xfce 4.14.1
           Distro: MX-19beta-2.1_x64 patito feo September 8  2019
Machine:   Type: Desktop System: Gigabyte product: N/A v: N/A serial: <root required>
           Mobo: Gigabyte model: F2A68HM-H v: x.x serial: <root required>
           UEFI: American Megatrends v: FB date: 04/22/2015
CPU:       Topology: Quad Core model: AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G bits: 64
           type: MCP L2 cache: 2048 KiB
           Speed: 1455 MHz min/max: 1400/3100 MHz Core speeds (MHz): 1: 1605 2: 1878 3: 1397
           4: 1397
Graphics:  Device-1: AMD Kaveri [Radeon R7 Graphics] driver: radeon v: kernel
           Display: x11 server: X.Org 1.20.4 driver: ati,radeon unloaded: fbdev,modesetting,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD KAVERI (DRM 2.50.0 4.19.0-6-amd64 LLVM 7.0.1)
           v: 4.5 Mesa 18.3.6
Audio:     Device-1: AMD Kaveri HDMI/DP Audio driver: snd_hda_intel
           Device-2: AMD FCH Azalia driver: snd_hda_intel
           Device-3: Logitech Webcam Pro 9000 type: USB driver: snd-usb-audio,uvcvideo
           Sound Server: ALSA v: k4.19.0-6-amd64
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: eth0 state: down mac: 40:8d:5c:0d:62:1b
           Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
           IF: wlan0 state: up mac: 60:e3:27:08:b6:6c
Drives:    Local Storage: total: 698.66 GiB used: 117.61 GiB (16.8%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
           ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
           ID-3: /dev/sdc vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 225.99 GiB used: 7.83 GiB (3.5%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 10.2 C mobo: N/A gpu: radeon temp: 11 C
Info:      Processes: 218 Uptime: 1h 02m Memory: 14.63 GiB used: 1.63 GiB (11.1%) Shell: bash
           inxi: 3.0.33
rich@mx:~
#257 Post by dolphin_oracle »
JayM wrote: Wed Sep 11, 2019 10:14 pm Maybe a timeout that's too short?
might be a factor I guess. the timeout is set to 5 seconds. but you would think that if I could get to the part with the timeouts, the tmp folder would have already been created, because that's where the repo info downloads to.
JayM
#258 Post by JayM »
richb wrote: Wed Sep 11, 2019 10:20 pm I do not see that on my installed system. Debian backports pops up in a couple seconds. Pretty fast computer. Is that the difference?
I'd guess not as it works on my slow computer running live on USB2.0. Debian Backports takes several seconds to come up, like 15 or more, but it eventually does. I'd say the slow or flaky Internet connection is the issue, though I can't say why it's not creating the temp directory.
chrispop99
#259 Post by chrispop99 »
dolphin_oracle wrote: Wed Sep 11, 2019 10:00 pm
[/code]
Something's not right; loads of output, but nothing happens?
DELL XPS 15
Lots of test machines
#260 Post by fehlix »
To avoid potential timeouts we might consider to replace the use of ftp.debian.org / ftp.us.debian.org for fetching backport package list and packages to the debian's used mirror service at deb.debian.org.
Locked
